It is currently Sun Feb 25, 2018 5:00 pm
PostPosted: Sat Feb 10, 2018 9:09 am
3-Tech cam for 1998 and up Swift 1.3 16 valve engine. New and unused. Mike's cam for overall performance upgrade. I no longer need it. $180 + $20 shipping from Austin, Texas to you in the USA.
PostPosted: Fri Feb 16, 2018 3:35 pm
I'm interested, what's the profile?
PostPosted: Fri Feb 16, 2018 7:35 pm
Probably 192/198 duration at .050" and .340" lift
PostPosted: Sat Feb 17, 2018 9:34 pm
From posts around here apparently that's a hell of a grind for the 16v SOHC and makes up for the restricted exhaust! Though is there a wilder grind that would match up a lil better with that 4/2/1 header I bought a couple years back from you and 2.25 in exhaust with 45mm tb with port matched(ish) intake? I don't mind a lumpy idle if that's what the trade off is (thought I would like to avoid CEL), I just wanna finally put a cam in this thing while I work on my GT!
