It is currently Tue Oct 17, 2017 4:50 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Wed Feb 09, 2005 12:14 pm
Hello all, screwedzuki here. i am posting this up here to see what the interest would be in a multilayer metal head gasket for turbo and NA cars. what this would allow you to do is be able to run in excess of 30psi without having to O-ring your block. if your block is already O-ringed that not a prblem as this head gasket will work with your O-rings and allow you to run in excess of over 50psi.
these head gaskets are made by COMETIC they make all the head gaskets for NASCAR and also for alot of american domestic vehicles, and foreign imports, such as the DSMs, Nissan, Honda, and Toyota.
if there is interest then please let me know. we have to get a group buy going and the min order is 150 pieces i am going to post this up on as many sites as i can to try and get this going. and the good thing about this is that its not a one time thing, if we can get 150 of them sold then it will be a piece that cometic stocks from then on
here is the price structure for all those interested.
if we sell
150-110 pieces, price = $60.00 US + shipping apiece
109-90 Pieces, Price = $70.00 US + shipping apiece
89-80 Pieces. Price = $80.00 US + shipping apiece
79-70 Pieces, Price = $90.00 US + shipping apiece
the retail price of this unit if you dont get in on the group buy will be $95 US + shipping apiece.
i hope i can generate alot of interest in this item as it is not very expensive and can be a cheap bit of insurance in knowing you wont have to replace the head gasket ever again because of a premature failure.
oh and this piece is going to be made for the DOHC 1.3 but it will most likely fit the SOHC 1.3 as well.
thanks and if you have any questions please feel free to ask.
PostPosted: Wed Feb 09, 2005 5:28 pm
damn that sounds pretty good do u know how thick these gaskets are?
i don't need one right away but when i want to go turbo next year this seems the right thing to do :) i hope u will get it off the ground
Lightweight swift with B16A1
UPDATED 15-02-2006http://www.cardomain.com/id/blurpie and http://swift.carsforever.nl
Q: Why did God create blondes?
A: Because sheep can't bring beer from the fridge.
Q: Why did God create brunettes?
A: Neither could the blondes.
PostPosted: Wed Feb 09, 2005 7:52 pm
I'd be down for 2 of them if the deal goes through.
PostPosted: Wed Feb 09, 2005 9:47 pm
I'm in too.
Wilfredo
PostPosted: Thu Feb 10, 2005 11:30 am
the thickness had not been nailed down as of yet, but i can tell you it will be between .040 and .045.
also i can get bore size for 74mm 75mm 76mm 77mm and even the 78mm
please tell anybody on this forum that might be interested in this, as we are trying to get this rollig as soon as possible
thanks
PostPosted: Fri Feb 11, 2005 12:20 am
Count me in for one.
PostPosted: Fri Feb 11, 2005 1:08 am
count me in.
i will get the 78mm.
PostPosted: Fri Feb 11, 2005 5:46 pm
The mad quebecer
The mad quebecer
Do you have more info on the gasket itself?
PostPosted: Fri Feb 11, 2005 6:08 pm
what info exactly would you like to know. please ask your questions here and i will answere them. im sorry i guess i just dont know what it is you are asking.
PostPosted: Fri Feb 11, 2005 7:41 pm
count me in for two @ 74mm
PostPosted: Sat Feb 12, 2005 5:18 pm
The mad quebecer
The mad quebecer
Do you have any pictures of the gasket material?
PostPosted: Sat Feb 12, 2005 8:02 pm
check out there website at http://www.cometic.com they have some pics. and ours will look just like the one on their hompage, it will just be cut to fit our car.
and i dont have a pic of one for our cars as they have yet to be produced thats why im trying to put together a group buy.
if i have not answered your question to your satisfaction im sorry, ask it again and i will try to do better. :D
PostPosted: Sat Feb 12, 2005 8:17 pm
MLS (Multi Layer Steel)
The Cometic MLS gasket is comprised of three layers of stainless steel. Cometic uses stainless steel for increased strength, its ability to rebound and corrosion resistance. The out layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material (viton) designed to meet the demands of a variety of harsh sealing environments, load conditons and surface finishes. The Viton coating is heat resistant to 250 degrees Celsius or 482 degrees Farenheit.
The center or shim layer of the gasket is comprised of an uncoated stainless steel layer, which can be varied to accommodate multiple thickness requirements. The MLS gasket is ideal for both aluminum heads to cast iron blocks and aluminum heads to aluminum blocks.
The compostion of the MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary. By design the MLS gasket promotes an even torque load across the sealing surface allowing for measurable reduced bore distortion.
Availble thickness: .027" .030" .036" .040" .045" .051" .060" .065" .071" .074" .120"
i can get any bore from 74mm to 78mm in any thickness.
I hope this answered any possible questions. if not please feel free to ask. thanks.
PostPosted: Sun Feb 13, 2005 6:21 pm
I'm interested!
What will the shipping (if possible) be to sweden?
PostPosted: Sun Feb 13, 2005 7:21 pm
Does anyone know what the thickness is of the OEM head gasket?
PostPosted: Sun Feb 13, 2005 10:14 pm
stock head gasket is about 1.2mm = 0.047"
PostPosted: Tue Feb 15, 2005 12:48 pm
runbag wrote:
I'm interested!
it will be around $10-$12 for up to 4 gaskets. that is a rouph guestimate that we have come up with from size and weight.
PostPosted: Thu Feb 17, 2005 11:03 am
here are the totals so far.
teamswift has spoken for 10 gaskets
redline gti has spoken for 12 gaskets
uk swift has spoken for 0 gaskets
that puts us at 22 gaskets, 48 shy of our min70 needed. this isnt going to happend if we cannot get more people commited. so please tell everyone you know about this group buy, its going to take community communication. and right now i have less than 600 hits between all 3 boards, with over 5000 members. so please tell everyone you know. thanks
PostPosted: Sat Feb 19, 2005 5:16 pm
what about gaskets for us 3cyl 1.0l turbo sprint guys :)
PostPosted: Sat Feb 19, 2005 7:59 pm
well you can place an order for 150 of them and i will have them to you asap. i cant even get 30 orders for the 4cyl 1.3 + 1.6 liter guys so i think you might be asking a little much. :D
PostPosted: Sat Feb 19, 2005 8:28 pm
I guess that ordering one single gasket is possible even if this "group-buy" wont go thru?
PostPosted: Sun Feb 20, 2005 6:12 am
well i'm in for defenately 1 ( maybe 2 ) .
but i need a gasket that is thicker than oem spec.
so thicker thand 0,045". i think i prefer a thickness of 0,074"
so about 1,9 mm.
like i said:
i'm in!
:lol:
1298cc with a supercharger.........
PostPosted: Sun Feb 20, 2005 1:18 pm
For the money I would be in (for 2), but I cannot wait too long and I'm affraid it can take a lot of time before you have enough buyers :(
Do you have any idea?
PostPosted: Sun Feb 20, 2005 2:08 pm
Put me down for 2.
Lawrence
PostPosted: Sun Feb 20, 2005 4:57 pm
we are at 26 gaskets, this is kind of dissappointing that i cant make this happen. and if i dont sell atleast $6500 US worth of gaskets then this isnt going to happend and right now only having 26 gaskets commited that is putting the price at $250 a gasket, so if we could at least double this # then to 52 gaskets sold then that would only be $125 a gasket, thats still high but i will make a commitment that i will sell everybody that helps with the original purchase gaskets at dealer cost, after we get to where we can purchase the original 150.
or if i can get vouchers for 150 gaskets i will sell these gaskets for $46 US apiece from this original group buy. after they are gone, the price will go back up. this is a last ditch effort.
and to all those who have alreay vouched then your price will go down to $46 US apiece as well for every one you have vouched for. but to make this happen we have to have atleast 150 of these paid for. becasue that is cost, to make this happen.
