It is currently Wed Feb 21, 2018 8:38 am
PostPosted: Sun Feb 18, 2007 1:52 am
With the new shop I'm working at, I've got a great supplier for custom pulleys and I'm having them make some pulleys w/ the 60-2 trigger wheel built in for some alfa romeos already.
I haven't gotten any quotes yet, but this would be for a single belt pulley (like the underdrives) with the trigger teeth built in. compatible with any of the multi-rib 5-bolt cars... cost should be do-able under/around $100
PostPosted: Sun Feb 18, 2007 12:05 pm
I'm In. Any pics? I will love this since I have a crank trigger ignition on my race swift.
Bolivar
PostPosted: Sun Feb 18, 2007 1:31 pm
here's a big question, teeth on the front or back of the pulley, & if you already have a setup, where's your sensor located as most systems want the missing teeth 12-13 teeth before the sensor.
using a crank trigger allows you to completely delete the stock distributor and run a dis system, not just for racing, it would make fitting the engine in a rwd config very easy.
PostPosted: Sun Feb 18, 2007 8:15 pm
some pics would be good!
Lee, Singapore
