It is currently Wed Jan 17, 2018 2:40 am
PostPosted: Sun Mar 22, 2009 12:42 am
I'm working on some extra thing to make some money 8) .I've got some custom made hard polyurathane motor mount inserts,and some TBI spacers in the works.The mounts I think are around $30+s&h and the tbi spacers well I'm haveing trouble decideing want material to make them from and ideas??? let me know
PostPosted: Mon Apr 13, 2009 11:05 pm
I might be interested in a mk 2, passenger side mount. Got pictures?
PostPosted: Wed Apr 15, 2009 7:11 pm
what do you mean by inserts? things you put in the stock rubber holes? or a poly bushing to replace the rubber in the mount?
Suzuki Gold Master Tech
PostPosted: Wed Apr 15, 2009 10:31 pm
Well I plan on have a solid piece of the polyurthane piece that would need to be pressed in or maybe...sledgehammer :shock: ..and yes the old rubber stuff would need to be removed..I'm just waiting on some quotes from companys???I looking for the best bang for the buck 8)
PostPosted: Sun Apr 19, 2009 10:10 am
i'm interested in 3 engine mounts if the price is better than the existing products.
PostPosted: Sun Apr 19, 2009 11:04 am
Well I have 1 quote and still waiting on 2 more??I would like to ask what COLOR would people like for the motor mounts??? I'm not picking but I would like to buy a color everyone would like...I have some example of the colors posted below...
PostPosted: Sun Apr 19, 2009 11:42 am
black has the broadest appeal, so companies start with it.
looking for:
PostPosted: Sun Apr 19, 2009 3:06 pm
Suzuki tends to be red or blue.
I like blue or red, my valve cover off of the G16 I got the header from was powder coated dark blue. Black does blend in the easiest, and look stock.
My cars:
PostPosted: Sun Apr 19, 2009 8:05 pm
I can't even see them on my car who cares what color it is? :lol:
i'll say black or red
PostPosted: Sun Apr 19, 2009 8:17 pm
banned and still posting
black.... and I want 3.
PostPosted: Sun Apr 19, 2009 11:13 pm
OK Then BLACK it is. I'm just waiting for info from 2 suppliers,then I can order some stock and have them worked and then be ready to go!!
PostPosted: Mon Apr 20, 2009 11:00 am
Before ordering a trailer full of mounts you should give us the final price :wink:
urethane mounts are already available elsewher, i'm looking for a cheaper alternative. i've got hockey pucks right now, it's not doing the job. they keep falling out of the brackets.
PostPosted: Mon Apr 20, 2009 11:14 am
Understand mine will not have those little lips at each end of the bushings mine will be smooth and need to be pressed into the mount..I would like to price them around 35-45 bucks+S&H..That will include the bushing and steel insert for the bolt to slide in...
PostPosted: Mon Apr 20, 2009 11:38 am
Please offer it with a stainless insert. :)
My cars:
PostPosted: Mon Apr 20, 2009 11:42 am
That sounds doable!! 8)
PostPosted: Mon Apr 20, 2009 12:29 pm
Not all urethane is created equal.
As you can see here
http://www.mcmaster.com/#8644k11/=1j278y
some of us have been adding these caulk products to holes we cut in rubber bushings, and let sit 48hrs.
Hardness Shore of 80 works well. 94 is stiffer
geofarace, Do you have a choice?
looking for:
PostPosted: Mon Apr 20, 2009 3:01 pm
I'm in for all 3.
Red if available. Black OK.
Harder durometer preferred.
I'm already running the "tube o silicon" modded mounts and it was a negligible improvement.
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Mon Apr 20, 2009 6:02 pm
Ok well for the harder durometer I have some choices and maybe we can vote!! Here we go---75D--80A--90A--95A--I think everyone would like the 90A but ya can give some input!! :D
PostPosted: Mon Apr 20, 2009 6:18 pm
How about solid steel painted black? Not really looking for "comfort"....
PostPosted: Mon Apr 20, 2009 6:35 pm
Well I understand why you would like solid steel because of your racing but the 95A is the hardest ava??
PostPosted: Mon Apr 20, 2009 9:11 pm
For the first run, I'd go with a bit softer compound. Like was earlier suggested the 80A. I'm not building some race monster, and most people aren't. So I can sacrifice a little hardness to cut down on alot of transferred vibration.
My cars:
PostPosted: Tue Apr 21, 2009 4:57 am
agreed.
looking for:
PostPosted: Tue Apr 21, 2009 5:02 am
:idea:
a local machine shop can likely make some and press them in your mounts.
:idea:
have a few extra made and sell them to our other racers.
looking for:
PostPosted: Sun May 17, 2009 10:19 am
any updates on this? what price is it gonna be?
PostPosted: Sun May 17, 2009 10:36 am
Well I got the stock in but the company sent the wrong size cause there are 2 different size bushings on our cars one was right the other size was off ..prices would probably stay between 35-45 just waiting till i can find some stainless inserts for the bolts!
