It is currently Tue Oct 17, 2017 12:18 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sun Nov 15, 2009 9:34 pm
thanks mr.pipe! im trying the same from a local parts store(oreily's auto,autozone,carquest,mom & pop's).
Multi-Layer Steel
MLS consists of multiple layers of stainless steel substrate with full or half embossments that give the layers function. This product can include a stopper at the combustion seal to limit motion and provide multistage gas sealing. Primary elastomeric coatings provide microsealing for the head, block and gasket layers. Secondary coatings enhance cold-seal capability, reduce friction and prevent sticking.
Features and benefits:
Requires lower clamp load to seal
Decreases cylinder head gasket contribution to bore distortion
Rigid body improves bolt load retention.
Steel construction provides control of compressed gasket thickness.
Robust design resists thermal and chemical attack.
Active seal conformability and resiliency allow for higher flange deflections.
Design permits flexibility to accommodate multiple piston-to-head clearances.
Bong,Bong,Bong....zuki's
PostPosted: Wed Nov 18, 2009 7:53 pm
I got the call that my gasket was in at the distributor late this afternoon...guy there says...
FPHS 9683 PT1 ....doesn't look like a MLS...looks graphite composite!
I'll let everyone know when it's in my hands tomorrow.
Darcy
PostPosted: Thu Nov 19, 2009 7:00 pm
The Felpro gasket from that part number is not MLS, it is a graphite composite like the Felpro head gaskets i've been using till now. I will quote the 2 Felpro gasket numbers, and whatever meausured differences i can find between them. ....deciding what head i should install now!
Darcy
PostPosted: Fri Dec 04, 2009 9:16 am
(506) 2242-7000 costa rica suzuki parts dept!
http://www.suzukicostarica.com/
http://www.suzukipanama.com/
Teléfono: 260-6474
http://www.simpson-motors.com
Simpson Motors Ltd
Warrens, St. Michael
Barbados, W.I., BB22026
Tel: (246) 417-7777
Fax: (246) 425-2889
Customer Service & General Enquiries:
info@simpson-motors.com
