It is currently Thu Oct 19, 2017 1:47 pm
 Post subject: Laser engraving
PostPosted: Thu Dec 08, 2005 6:22 pm
http://www.makezine.com/blog/archive/20 ... rbook.html
This is what you need for valvecovers and larger things like that. The machine I used was only good for items smaller than a valvecover, and shorter.
I no longer work where I used to, but if anybody is interested I can try to point you in the right direction to local options.
PostPosted: Wed Dec 14, 2005 9:47 pm
What about engraving degree marks on a set of cam gears? I've got a set of Crane adjustable gears but they don't have lines or numbers for the degrees.
PostPosted: Thu Dec 15, 2005 10:55 am
Yeah I can do that, circular things are no problem.
got a picture so I can look at where the marks would need to be?
PostPosted: Thu Dec 15, 2005 11:16 pm
I can get you a pic of them this weekend. I've got to "unbury" a few things.
PostPosted: Fri Dec 16, 2005 12:01 pm
I was also thinking of doing the same thing on underdrive pulleys, so there's a spot for the timing strobe to catch. I will to mine, at least.
PostPosted: Sat Jan 14, 2006 5:20 pm
could you put "GTi Turbo" on my cam cover
PostPosted: Fri Jan 20, 2006 12:32 pm
depends on how tall the cover is, and how big you want the lettering.
to be real honest, I don't think it'd work out too well because of how small the engraving chamber is. I can do about a 2" dia. circle each pass. When I originally posted this idea, I had marking on smaller objects in mind. Shift knobs, Underdrive pulleys, cam gears, things that size.
PostPosted: Mon Jan 30, 2006 1:52 am
What's the max size you can fit in there?
<b>THANK YOU Wagon, T3Ragtop, and Casey for getting us home.</b><p>
PostPosted: Mon Feb 20, 2006 4:57 pm
I can engrave about a 2.5" dia. circle in one shot. I can move it and shoot again, but continuity gets sketchy if it's a really big object, as the sides of the chamber get in the way.
I'm not too sure if the focal depth will allow for a valve cover off a GTi...
in fact I'm almost certain it won't fit. I'll get dimensions and post back.
PostPosted: Wed May 10, 2006 2:42 pm
Ok I'm back. Sorry I took so long to get back on this. I'd have to see what the cam cover looked like first. get me pictures of all angles if possible. Cam gears as well. Shift knobs, keychains, yadda yadda yadda are all possible. Or, I can do jewelry too. :-P
PostPosted: Fri May 12, 2006 11:39 pm
How much would you charge for something like this?
PostPosted: Sat May 13, 2006 12:13 am
How about Titanium rings about 7/8" OD by 3/8" wide? I just machined some up and was wondering if you could engrave words on them? what would it cost roughly?
Dan
PostPosted: Sat May 13, 2006 12:32 am
Dan
Funny you should ask, that's what we use it for most of the time. :D Only on Tungsten Carbide, not Titanium. Makes no difference though, it's just as easy.
Engraving words, no problem. I normally say I only do Block or Script fonts, but I can do any font you have on your computer and know how to email to me. That doesn't mean it'll look good though.
Do you have a logo or hallmark to put inside? It's important.
PM me.
 Post subject: Re: Laser engraving
PostPosted: Wed Oct 08, 2008 6:09 am
whats the pricing ? i need something small like my oil cap .. pm me.
