It is currently Sun Oct 22, 2017 2:17 am
PostPosted: Fri May 16, 2008 5:21 pm
Just found this on the net, felt I should share it with ever one. Its the model type for the SUZUKI SWIFT1.0 86-89,1.3 84-89,GTI 1 front wheel bearing under three different manufactures
SKF : FW22/VKBA1930
FAG: 805172/BAH0087
NSK: 36BWD04
Here is the site I got it from: http://www.sh-weiya.com/other/Double-ro ... arings.htm
PostPosted: Fri May 16, 2008 8:06 pm
Thanks for that.
Already copied both pages to my computer.
