It is currently Mon Feb 19, 2018 8:57 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 186 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Tue Mar 02, 2004 5:15 pm
What is a Group A racing cam?
PostPosted: Tue Mar 02, 2004 5:29 pm
group A:
duration (not.050): ex- 256, in- 264
valve lift (mm): ex 8.85, in- 8.85
ex.op: 54, ex.cl: 22, in.op: 28, in.cl: 56
PostPosted: Wed Mar 03, 2004 5:44 am
Shouldn't be a problem. US$275/exchange.
PostPosted: Wed Mar 03, 2004 3:43 pm
Great. And how can I be sure, that cams will have that numbers?
I am from Europe, so if i get them from you, i have to first buy here stock ones and send it to you?
Lander
PostPosted: Wed Mar 03, 2004 4:26 pm
Give me a proper Duration number(at .050" lift), and I can give you a guarantee.
Yes, it works best if you send me cams first,otherwise I have to charge a core charge($$).
PostPosted: Wed Mar 03, 2004 5:57 pm
Lander wrote:
...........i have to first buy here stock ones and send it to you?
...................suprf1y........thats remind me something..............hehe
PostPosted: Wed Mar 03, 2004 7:38 pm
Can you explain it for me please?
PostPosted: Wed Mar 03, 2004 8:48 pm
...............i have the same prob as u mate.............i am looking to buy stock cams, to send them to suprf1y.........but i cant find anywhere at the moment.
by the way...........which part of Europe r u from?
PostPosted: Wed Mar 03, 2004 8:53 pm
Czech republic, it is middle of Europe.
It is possible to change duration of stock cams to group A cams?
Any other mods I need to do to install that cams?
Lander
PostPosted: Sun Mar 14, 2004 2:31 pm
How much meat are we going to loose off the base circle? For us guys with shims this may cause some problems.
Malcolm
'95 Metro 1.0 / 5 spd
165,000 miles
PostPosted: Sun Mar 14, 2004 5:11 pm
I'm assuming that you have a 3cyl. All of the grinds are 'mild' enough that the hydraulic lifter takes up the lash, and no shims are required. All the listed cams are useable out of the box. I'm working now on a few race profiles that will be borderline with the stock lifters, as well as a solid lifter race cam, which will require shimming for adjustment.
PostPosted: Sun Mar 14, 2004 6:22 pm
i guess group A cam´s can work with the stock lifters...
what do you ppl think?
PostPosted: Sun Mar 14, 2004 6:48 pm
yeah they ll work fine with the stock lifters..........as the lift are 8.85mm for both inlet and exhaust. for lifts 9mm or higher you need new lifters. if i am wrong pls correct me.
PostPosted: Mon Mar 15, 2004 12:28 pm
I guess the only other thing would be, what's the computer going to think about it? Do you have any of these cams running yet?
I've been fooling around with Desktop Dyno trying to get the 1.0 put in. So far those cam numbers look they're adding almost 20 HP!
Who knows the valve sizes on these things?
Malcolm
165,000 miles
 Post subject: .....
PostPosted: Mon Mar 15, 2004 7:18 pm
Senior Member
So you do not build up the cam lobes first, before re-profiling?
PostPosted: Mon Mar 15, 2004 8:42 pm
Yes there are some out there and they are working fine with the stock computer.
The valve sizes are 35mm Int. 28mm Exh.
No, the lobes aren't built up before grinding, there is no need to, and you don't want to to that unless it is absolutly neccesary.
PostPosted: Mon Mar 15, 2004 11:37 pm
Thanks suprf1y,
That sounds good. What kind of 'seat of the pants' difference does it make? It's sounding like something I'd like to try. That is, unless I find a G13 in the near future. :)
Malcolm
165,000 miles
PostPosted: Tue Mar 16, 2004 12:00 am
Here's the numbers I'm getting in Desktop Dyno with the new cam
Stock exhaust
70 hp @ 6500
63 ft lbs @ 5000
With header
86 hp @ 6500
74 ft lbs @ 5000
Sound close?
Malcolm
165,000 miles
PostPosted: Sat Mar 27, 2004 4:34 pm
Due to requests, I've opened up a PayPal account, and you can now use your credit card to buy truckloads of camshafts.
I will be testing the 1.0l 3cyl 'race grind' in the next week, and will have available a .330"(8.4mm) lift/235 dur@.050 grind for the GTi. That will be a real high revver!
PostPosted: Sun Mar 28, 2004 2:39 pm
these cams are sounding great. I have '92 3 banger and i want one of ur cams but do u have another setup except for race? like a street cam is what im after, what kind of hp/ ft lbs am i going to see?
PostPosted: Sun Mar 28, 2004 5:11 pm
These are the street grinds.
89-up 3cyl.
Lift ________Dur at .050"
.340_______212
.350_______220
I can't give you hp, or torque numbers, because every setup is different.
Please PM me if you are need more info.
PostPosted: Tue May 11, 2004 3:42 pm
what important mods or parts would need to be put on a metro when using one of these cams?
1996 Geo Metro - 3 cylinder - 1.0L
PostPosted: Tue May 11, 2004 4:01 pm
Nothing, just throw it right on.
 Post subject: cam mods
PostPosted: Tue May 11, 2004 5:32 pm
Any thing you can do to get more air in and out of your motor will increase the power. hi flow air filter (K&N), colder air, and free flow exhaust. all will work better with a bigger cam. The trade off is with longer duration you will lose bottom end torque. If you have an automatic this is harder to live with. The motor is just an air pump- more air + more fuel will make more power - up to a point!
One other thing “motors do not know what is written on the valve cover”. You can hotrod anything!
PostPosted: Tue May 11, 2004 7:13 pm
Both answers were right. No mods are required for the installation of one of my 3cyl. cams.
Larry is correct, and the 3cyl. is particularly sensitive to the type of mods he suggested. First and foremost, you should be looking at a free flowing exhaust, at least 1 7/8" or 2". The stock exhaust is VERY restrictive. After that, you will see much better results from a cam change. I always recomend that people do the exhaust first, before the cam, or at least be aware of the potential results first.
