It is currently Wed Jan 24, 2018 6:41 am
 Post subject: Distributor Shaft Seals?
PostPosted: Thu May 15, 2014 5:47 pm
Anyone know the original Suzuki part number for the internal seal on the Swift distributor shaft seal? Not talking about the o-ring at the bottom. Need the one that is actually internal that keeps the oil from getting inside of the distributor. Please, no aftermarket number, thanks.
PostPosted: Fri Sep 12, 2014 8:29 pm
For the DOHC motor? If so I have a rebuild kit. Bearing and seals.
PostPosted: Sat Sep 13, 2014 7:31 am
Mine is the 3. I was looking for that inner seal that stops the oil from seeping inside the distributor itself. Not the o-ring on the outer shaft.
PostPosted: Sat Sep 13, 2014 7:53 am
AEO25SK is what I can see on the one in the bottom of my 3 cyl vacuum advance dizzy.
PostPosted: Sat Sep 13, 2014 8:10 am
this is a picture of a rebuild kit a Suzuki dealer sent me. The seal I am looking for is circled.
PostPosted: Sat Sep 13, 2014 3:44 pm
Yea, the 3cyl is different.
PostPosted: Mon Oct 06, 2014 4:48 am
The 95 and up seals are all the same.
The early vaccum advance distributors and the
pre ODB1 distributors have a much larger seal bearing and shaft.
Some of the ODB1 distributors aare the same as the 95 and up
Bottom line.... There are 3 different shaft seals and bearings used.
I build distributors all the time.
Just curious but what did the suzuki kit cost you?
Fainya
PostPosted: Mon Oct 06, 2014 5:41 am
Actually didn't buy it. The dealer said the kit wasn't available any longer. He said it was a picture found in the computer for a 3 cyl Suzuki.
