http://www.teamswift.net/
Distributor Shaft Seals?
http://www.teamswift.net/viewtopic.php?f=17&t=58054
Page 1 of 1
Author:  fastvan67 [ Thu May 15, 2014 5:47 pm ]
Post subject:  Distributor Shaft Seals?
Anyone know the original Suzuki part number for the internal seal on the Swift distributor shaft seal? Not talking about the o-ring at the bottom. Need the one that is actually internal that keeps the oil from getting inside of the distributor. Please, no aftermarket number, thanks.
Author:  92GT [ Fri Sep 12, 2014 8:29 pm ]
Post subject:  Re: Distributor Shaft Seals?
For the DOHC motor? If so I have a rebuild kit. Bearing and seals.
Author:  fastvan67 [ Sat Sep 13, 2014 7:31 am ]
Mine is the 3. I was looking for that inner seal that stops the oil from seeping inside the distributor itself. Not the o-ring on the outer shaft.
Author:  aqqus [ Sat Sep 13, 2014 7:53 am ]
AEO25SK is what I can see on the one in the bottom of my 3 cyl vacuum advance dizzy.
Author:  fastvan67 [ Sat Sep 13, 2014 8:10 am ]
this is a picture of a rebuild kit a Suzuki dealer sent me. The seal I am looking for is circled.
Author:  92GT [ Sat Sep 13, 2014 3:44 pm ]
Yea, the 3cyl is different.
Author:  fainya [ Mon Oct 06, 2014 4:48 am ]
The 95 and up seals are all the same.
The early vaccum advance distributors and the
pre ODB1 distributors have a much larger seal bearing and shaft.
Some of the ODB1 distributors aare the same as the 95 and up
Bottom line.... There are 3 different shaft seals and bearings used.
I build distributors all the time.
Just curious but what did the suzuki kit cost you?
Author:  fastvan67 [ Mon Oct 06, 2014 5:41 am ]
Actually didn't buy it. The dealer said the kit wasn't available any longer. He said it was a picture found in the computer for a 3 cyl Suzuki.
http://www.phpbb.com/
