It is currently Sat Feb 24, 2018 2:40 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Sep 09, 2005 10:32 pm
I would like to purchase a +10 gear, how do I go about ordering one?
Jerry
PostPosted: Sat Sep 10, 2005 8:09 am
Jerry
Click on the 3tech in my sig. You will find my email address there.
PostPosted: Sat Mar 18, 2006 8:23 pm
El Pimpo del Geo
you have p.m.:D now that i have money you will be seeing it :P
 Post subject: 93 1.0 non-turbo
PostPosted: Fri Nov 24, 2006 6:26 pm
What's the best advance for bone stock AT w/ 2" exhaust?
Smile... not only is it contagious, but it really confusue people people
PostPosted: Sun Jan 14, 2007 12:15 am
anyone know if this guy is still around? No answer on my PM. Cheers
PostPosted: Sun Jan 14, 2007 12:41 am
I thought I did answer it. Sorry.
Not recomended for your application.
PostPosted: Sun Jan 14, 2007 7:19 pm
huh, I thought that would be the easiest way to to advance my timing as I can't find aftermarket spring/weights for the dizzy, let alone a vac adv. I suspect you are gonna say the valves will run too hot. Thanks for your time. Cheers, Paul
PostPosted: Tue Jan 16, 2007 10:22 am
You're confusing valve timing with ignition timing.
PostPosted: Tue Feb 13, 2007 1:28 am
You thought Jomo was bad
would +10 be ok for a '93 1.0 metro?
Car show that everyone should go to!
http://www.teamswift.net/viewtopic.php?t=30466
"FOREVER N/A 3cyl"
Limited Edition 3cyl. Batmobile(1993 g10 Metro)
1999 Jeep Cherokee 4.7L Stroker
 Post subject: timming gear
PostPosted: Sat Feb 17, 2007 12:51 pm
I have a 92 metro with a 1.0 what degree gear is best and how much for gear and shipping to Greer South Carolina 29651 .
Cars and Harleys
PostPosted: Sat Feb 17, 2007 10:57 pm
+10, but there are 2 different types of sprockets from 92-95.
Is it cast(5spoke), or stamped steel?
PostPosted: Sat Mar 10, 2007 3:31 pm
I have a 94 metro 1.0. Which one would be best? The car is 100% stock.
Also do you just bolt it in or do have to do other stuff to make it run properly?
PostPosted: Sat Mar 10, 2007 6:39 pm
Generally I would recomend the +10.
Read back through the thread for more info.
The 94/95 cars are the only ones I have sprockets for right now.
It is a simple bolt on with no mods required.
 Post subject: Re: sprocket
PostPosted: Mon Apr 09, 2007 10:44 am
Gibs4324 wrote:
i have a 99 3cyl i found a stamped steel one for the earlier models like 89-94 is there any way that would work on my car? I have searched and found no definite answer
It won't work.
You need a cast-type, 5 spoke wide sprocket.
Send me the stamped steel one, and $30, and I will send you a +10 in the style you need.
Normal price would be $40 shipped.
PostPosted: Mon Apr 09, 2007 11:30 am
Shipping for you would be about $5.
Think of the other members.
I really don't make hardly anything on these things, once you look at the time involved, packaging, cleaning, prepping, modifying, shipping, etc.
I have a hard time finding the stamped steel ones, and you would be enabling another member to have one.
Thats why I offered the deal.
PostPosted: Tue Apr 10, 2007 7:00 am
I think I have a couple extras.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Tue Apr 10, 2007 8:25 am
I will take any stamped steel sprockets that anybody has lying around.
I've cleaned out the 3 main wreckers that I deal with, at least a dozen times, and they are getting hard to get.
I can't pay much for them, like $5ea, +shipping, but look what I charge for them.
 Post subject: stamped gears
PostPosted: Wed Apr 11, 2007 2:07 am
I have 2 of them if you need them .I ordered a 10 degree gear from you a week ago I can send these I have when I recieve the other one I ordered. That way shipping will be less to you .
Cars and Harleys
PostPosted: Wed Apr 11, 2007 7:09 am
Is there any reason to play with the cam timing on a '92 1.3L 8-valve engine with your 375/216 cam?
 Post subject: Re: stamped gears
PostPosted: Wed Apr 11, 2007 9:25 am
Sounds good.
Keep me posted.
Yes, and no.
They are already phased pretty much where they should be.
If you had a real long duration cam, them it sometimes makes sense to advanced it to pick up some of the lost bottom end, or to shift the powerband down, yet still take advantage of the broad, and increased power of the longer duration.
You could probably advance it as much as 4 degrees (that would put you at 106 intake centerline, IIRC), and benefit.
The problem is that I don't have a +4 in the stamped steel.
If its a cast-type, then I could do it.
If you have an adjustable sprocket, make sure you use a degree wheel.
PostPosted: Wed Apr 11, 2007 9:29 pm
i have a 222/365 cam coming in will i have to mess with any timing before/after i add a +10 timing sprocket?
"FOREVER N/A 3cyl"
PostPosted: Wed Apr 11, 2007 11:40 pm
No.
Set the (ignition) timing the same. Advance until it pings, then back it off until it just stops.
