It is currently Sun Jan 21, 2018 7:57 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Apr 25, 2007 10:52 am
Do any of these have a positive effect on gas mileage, or are they strictly performance? BTW I have a 95 G10. :D
PostPosted: Wed Apr 25, 2007 11:26 am
Read the thread, its been covered.
PostPosted: Fri Apr 27, 2007 8:29 am
Ok, I've read some reviews on the +10 sproket and there seems to mixed reactions on gas mileage with it. Some had no recorded change in gas mileage, others had a small increase. So, good to go! Are there two different cam sprokets for my year, or was it a transition year where some things were being changed between them?
PostPosted: Fri Apr 27, 2007 8:43 am
94/95 are funny years, and you'll either have the 23mm, or 28mm wide sprockets.
You will have to check.
PostPosted: Mon Apr 30, 2007 4:17 pm
I'm assuming that measurment is from the center of the sprocket? Anyways, I'll make 2 measurements of the center and the OD and report back!
Edit:: Gotcha now ;)
UPDATE: Well, turns out my sprocket is 23mm, I will be keeping tabs on when you will be up and running again so I can get a +10 23mm sprcket from you. Thanks!
1995 Geo Metro LSI G10 5 speed. Cone air filter, TBI bridge removal mod, deleted rear seats.
PostPosted: Tue May 01, 2007 12:27 am
Its the width of the sprocket, not the diameter.
 Post subject: unsure of year
PostPosted: Wed May 16, 2007 7:25 pm
My 94 1.0 AT has had motor swapped. What exactly do you need to know, assuming it's from a 92-95, to ID the right gear. Also, is +10 my best bet, assuming it is a 94 motor, and any way to Verify the year of this engine? Once I know for sure what mine needs I'll be ordering 1 for me as well as 1 for a friend with a 92 1.0 MT
Smile... not only is it contagious, but it really confusue people people
PostPosted: Wed May 16, 2007 11:30 pm
Sprocket construction(stamped steel, or cast?)
if cast, what is the width?
PostPosted: Fri Jun 08, 2007 2:24 pm
I got my +10 sprocket in last night! I'll most likely install it when my rebuild's complete. Thanks!
 Post subject: finally!
PostPosted: Sun Jun 10, 2007 5:52 pm
Superfly,
Finally got a look at my gear. It's cast, and appears to be 28mm wide. Do you need same info for my friend's '92 1.0 MT, also? or is the year sufficient? I would like to order a gear for mine, and one for my friend at the same time, let me know what info you need. PM best for c/c info, shipping address, etc?
PostPosted: Mon Jun 25, 2007 2:19 pm
*crosses fingers*
Hope you guys have one that will fit on a 98 1.3L.
I sent an email on your site.
PostPosted: Sat Jul 28, 2007 8:31 am
hotrodray1 wrote:
I am needing a cam gear for a 1989 swift glx with a 1993 1.3 SOHC . What do you think i need to use? I may also get a cam in a while it is a auto trans. Thanks
The advanced timing sprockets are not recomended for the 1.3 8V motors.
PostPosted: Sat Jul 28, 2007 6:13 pm
I have a g16 sohc 16 valves.
what do you recomend?
thanx
fede
PostPosted: Mon Jul 30, 2007 8:24 am
thanx
fede
If your sprocket has 2 slots, try the one marked E.
If not, get one from a GTi, and try that.
You don't need to advance these motors much, or at all.
PostPosted: Mon Jul 30, 2007 1:20 pm
Thanx for your reply.
My engine has the max torque at 3500 rpm and max power at 6000.
I read somewhere that if I advance the cam I can move the torque peak upwards.
My car is pulling quite well from idle to near 6k. I can cruise at 50kms/hr. in fifth gear. I think that if I can move the torque peak to 4000 or 4100 rpm it will pull harder in the higher revs (never more than 7k). Am I saying crap??
Will an adjustable cam gear help me here?
thanks again
fede
PostPosted: Mon Jul 30, 2007 11:32 pm
Well, you have it backwards.
Advance the valve timing to move your powerband down.
It really is intended for fine tuning(unless its so far out from the factory that it needs to be corrected), and what you are looking for seems to be a little more than that.
If you have the double slot sprocket, and its already on the E mark, then put it on the I.
It might get you halfway there(4 degrees retard)
PostPosted: Mon Feb 11, 2008 4:13 am
Im curently on a project car its a 95 swift, and im putting in a "01" g13b 4 cyl fuel injected motor, do you have a cam gear for this perticular motor, and what should be my setting. and do you have a cam 4 me ??? http://www.teamswift.net/viewtopic.php?t=35910
PostPosted: Mon Feb 11, 2008 8:47 am
You don't need a sprocket for that motor. Use the 'E' setting on your stock one.
My new cam profile for this motor is a nice one. Good idle, no codes, and it adds good lift, duration, and RPM.
.340" lift, 192int/198exh duration
Thats a 8 degree gain on the intake and a 14 degree gain on the exh.
The exh. duration, and extra .060"(!!) lift gain.
I can go a little milder, or a little wilder than this one, but not much wilder, if you want it to be code free.
PostPosted: Tue Apr 15, 2008 9:48 pm
Hi 3 tech,
Someone said I might be able to get a stock camshaft pulley for my 91 geo 1 liter?
Thanks,
Prion
