It is currently Tue Jan 16, 2018 7:52 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 15, 2004 12:05 pm
the 8v engine uses a throttlebody injection or carb'd setup, so it's not comparable to the multiport setups with their individual injectors.
PostPosted: Thu Apr 15, 2004 12:29 pm
"the 8v engine uses a throttlebody injection"
I know it, but my question wasn't that :)
My question was: how much is the swift 1.3 8V (68hp) fuel rate ?
PostPosted: Thu Apr 15, 2004 12:31 pm
Sorry
My quaestion was: how much is the swift 1.3 8V (68hp) injector's flow rate ?
PostPosted: Mon Apr 26, 2004 7:31 pm
I have a 94 mk3. In process of boost swap from NOS. I just took apart fuel rail hollow and large inside. See no problems cutting off regulator and adding own ends. I personally have done lots of research and will be using a H***a rail that will bolt on. Will use a modified factory H FPR with the B&M regulator adapter that will bolt on. Can use the factory banjo style fitting or use your own setup. Has port for gauge and auxillary fuel feed(extra injectors, NOS). Just my 2 pennys.
Frank
PostPosted: Thu May 13, 2004 6:45 am
does anyone know what the stock pressure for a gt swift's fuel system i did a test and got 31-32 and was wondering if thats what it should be. i also don't know if my car has the gti pump in it it might a redular swift/metro pump in it. thanks
PostPosted: Fri Feb 18, 2005 6:37 am
30-32psi on idle, 38-40psi on WOT should be ok as far as I remember.
Mk3 GTi Saudi Arabia edition.
PostPosted: Sat Oct 08, 2005 1:57 pm
pasd wrote:
Sorry
same question
PostPosted: Tue Sep 04, 2007 1:54 pm
Swift GT 59-72cc
Firefly Turbo 49-56cc
Sidekick 16V 39-49cc
so this is correct? I can use the 3 of the 4 stock gti injectors I have kicking around in my mk2turbo3 as an upgrade? I know they work good, I upgraded to some supra injectors for the supercharger on the swift, so I just have this sitting here.
I would have to change the wiring harness for them, but thats no big deal. If I plan to go over the 10psi, this would be good info to know
 Post subject: Re:
PostPosted: Mon Jun 15, 2009 10:10 am
unregulated psi with eng off and key on
3 cyl = 23-31 (13-20 at idle)
4 cyl = 23-30 (13 for at least 1 min after pump is shut off)
DOHC = 36-39 (26 for at least 1 min after pump is shut off)
viewtopic.php?f=2&t=43921
looking for:
