It is currently Sat Feb 24, 2018 9:56 am
PostPosted: Sat May 16, 2009 9:50 pm
Have you ever wanted a light under the hood or bonnet?
What if a hose comes loose at night on a dark road?
No fashlight/torch?
A 4W bulb under the hood could save the day !
image_id: 16571
Mine is wired into the parking lights because I have had a seperate switch that accidentally gets pushed during daylight hrs and goes un-noticed until the battery is dead.
Project Time: 3 hrs
Materials:
Duct tape of course
8 ft of black wire
8 ft of blue (or whatever) wire
a dual wire connector -- like used at the parking lights
2 straightened coat hangers
4 ft of string
1 ring connector for ground
soldering equipment or connector
light socket and bulb
I got the under hood lights from a Jaguar (1987-94 XJ6 and XJ12)
the socket is archaic and prone to corrosion but the PLASTIC lens is sooo rad.
the bulb they use is rated at 4W for a whopping 200 hrs.
Modern bulbs are available in 4W to 18W and 1500-2000 hr at the same cost.
The 168 type in Swift corner lights is 5W and 1500 hr.
A 194 can be used -- 4W and 1500 hr. The Long Life 194LL exceeds that.
The 921 type uses the same socket and is 18W and 1000 hr. The 921LL is 2000hr.
Before using a 921 consider that the heat may melt plastic lenses.
First
Assemble the mount, bulb, wire and socket.
Here is the Jag mount, 194 bulb and Swift socket which fits with a little filing of the mount.
image_id: 16584
Drill two 1/4" holes to match the mount. Choose a location where there is room for the socket and use screws that wont go thru the hood. :(
image_id: 16583
Fish a coat hanger thru the socket hole DOWN thur the channel of the hood and use the other coat hanger to hook it and pull it out
image_id: 16582
Tie the string onto the hanger and gently pull the string UP thru the channel,
image_id: 16581
Fasten the 2 wires to the string with tape
image_id: 16579
Pull the wires gently DOWN thur the channel
image_id: 16578
Attach the light assembly
image_id: 16568
Untape and fish each wire around the weld
image_id: 16576
Then fish each wire thru the squirter hole. pliers help.
image_id: 16575
Put the wires in a LOOM with the squirter hose and route under the fuse box. Install a dual wire disconnect to make it easier to remove the hood.
image_id: 16569
Locate the power source. I used the Left clearance/running light (under the headlight)
image_id: 16574
I have seen a lot of connectors fail so I solder whenever i can.
I melted off the plastic insulation and wrapped the new wire around and soldered.
Tape over the solder.
image_id: 16573
I crimped and soldered the ring terminal to the ground wire and attached it to the factory ground point.
image_id: 16570
Test the connections
image_id: 16572
Note: We could use a mercury switch at the mount for OFF/ON.
edit: good source for bulb details
http://www.donsbulbs.com/cgi-bin/r/t.pl ... bclick.y=0
looking for:
PostPosted: Sat May 16, 2009 10:11 pm
I think the Jeep Grand Cherokee has a light that is retractable that you can move anywhere in the engine bay. Just in case you want that.
94 Swift GTi 5spd
94 3cyl automatic 4 door
PostPosted: Sat May 16, 2009 10:53 pm
and the 70-73 240Z had a light with switch on a coiled wire. killed my battery.
i'll look at the Jeep for kicks. thanks.
looking for:
PostPosted: Sat Aug 22, 2009 6:05 am
I use a 3 LED touch-light I found in a dollar store. It runs on 3 AAAs, so no worries about draining the car battery, and it's completely portable. It came with an adhesive tape backing, to which I mounted a hard drive magnet. I use mine mostly as a cargo light, but it has helped out in the engine bay as well.
PostPosted: Sun Aug 23, 2009 12:22 am
Those both are fantastic ideas, will work great in the Great Pacific Northwest, and elsewhere
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Dale
