It is currently Thu Feb 22, 2018 4:09 am
 Post subject: g10 weber carb
PostPosted: Tue Sep 15, 2009 12:39 pm
Has anyone out there had any experience putting a weber on a G10? I am mostly concerned with mileage and reliability issues. I like the idea of simplicity.
 Post subject: Re: g10 weber carb
PostPosted: Tue Sep 15, 2009 2:04 pm
Check with Matt Dodd.
He did this:
Read all about it!
http://www.teamswift.net/viewtopic.php? ... 54#p336954
viewtopic.php?f=31&t=44293
http://www.teamswift.net/viewtopic.php?f=31&t=34970
By the time he gets done with that car, it'll give this deuce a bad time:
:D :D :D :D :D :D :D :D :D :D
If you want crazy fast, drop $1200 on a set of these:
and slap em on a DOHC.
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
