It is currently Mon Feb 19, 2018 9:32 am
PostPosted: Tue Oct 06, 2009 10:10 pm
I posted this on GeoMetroForum, but I figure a lot of newbies may need the help here also. Most of the time one of these Suzuki engines need a rebuild, it is due to burnt exhaust valves in the cylinder head, but whenever the engine is getting high on mileage, the piston rings could also be worn and this will call for a bottom end rebuild. If you already have the head off, rebuilding the bottom end is only a few hours of extra work and minimal parts are needed unless you find a cracked or broken piston or worn bearings. If you need info on rebuilding the cylinder head, you can read THIS GUIDE to help you out and then check out the more detailed info on head rebuilding HERE.
Parts needed for a bottom end rebuild usually consist of getting new piston rings and maybe some connecting rod bearings.
First thing to know is that the engine does not need to be removed for this job, but this one is already out and will make the guide easier for you to understand.
Remove the oil pan from the engine.............
Remove the oil pickup tube..............
Rotate the crank and start with one side and remove the 2 connecting rod cap nuts.........
Use a piece of wood and push the piston out the top taking note of the bearings.......
Be sure to keep all the parts in order of removal..........
Inspect the connecting rod bearings for wear. If you notice, these bearings are 2 kinds of metal and the silver layer should not be worn to the other layer. If in doubt, get new ones.........
Now on to the pistons. You can remove the rings quite easily by finding the gap on the top ring, and pull it up and then you can "roll" the ring right out of the groove quite easily. Place in order of removal to reference them later. Repeat with the other rings. If you have an XFi engine, you will only have 2 ring grooves instead of 3 like a typical G10. Once the rings are out, carefully inspect the piston sides (skirt) for any signs of cracks.
It's good to soak the pistons in solvent. You can use Kerosene for this and it works well. I cut 3 empty one gallon jugs and filled them with solvent and soaked the pistons overnight to help loosen the carbon deposits..................
I then used a wire wheel to clean the piston tops and the thin part of the sides just above the top ring groove. I don't suggest using a wire wheel or other powered tool on the piston skirts. These should clean up well with solvent.............
Now comes the time consuming part. You need to clean the carbon from those ring grooves. You can use toothpicks, small screwdrivers, scribe and pick assortments, paper clips, or even better, break or cut one of the old piston rings and use it to clean them grooves out from all the carbon. Careful not to "gouge" the piston, you are simply removing carbon deposits and after a soaking, the carbon is easily removed.............
Now on to the block. Clean up what you can and get the block deck clean from all the old head gasket material. I use a mild roloc disc on an air tool, but you can also do it the hard way with a razor blade and some emery cloth. Now is a good time to inspect the crankshaft bearings. I simply pulled one main cap off and inspected the bearing like the connecting rod bearings. No problem there, so I am leaving the crank in. If your engine had any knocking noises it's a good idea to look if the pistons and rod bearings were good. If you wish to do main rod bearings, now is the time. To hone the cylinders, you will need a 3" ball hone also known as a berry hone. It looks like a cluster of berries...............
Use some paper towels and wrap the crankshaft journals with paper towel and then some electrical or masking tape. This will keep the particles out of the oil galleries. Spray the cylinder walls down with parts cleaner and make sure they are clean. You don't want dirt in the sleeves. Now liberally coat the walls with either motor oil or do like I did and spray the cylinders with WD40, Blaster, or other oil. Some people may dispute this and suggest honing oil, but to each his own. Rotate the crank so it is at it's lowest point. Insert the honing tool with a clockwise twisting motion until fully seated............
Now pull the trigger at full speed and use a smooth up and down motion making sure to go down till you just feel it touch and back up to the top repeating this motion for about 10 to 20 seconds and do not stop in the middle of the cylinder. You must keep the trigger pulled and keep it spinning while you pull it all the way out when you are done so it does not leave scratches. I hope you got them safety glasses on......................
Carefully inspect the walls for a nice even pattern. It don't have to be a perfect cross hatch pattern, but should look uniform..........
Repeat on all 3 cylinders making sure to rotate the crank to the lowest point for each one. Once you are finished, you can do it like the book says and use soapy and water to clean the cylinder walls down :ermm:
Supposedly, this washes out the particles better than anything, but in my experience, this makes everything rust really fast including the crank journals. Also this engine will not be running after it's rebuilt until it's installed later and I don't like the rust idea, so I use parts cleaner and a soft cloth to wipe them out. I wait till dry and repeat a few times to make sure no dirt or stone material is left behind. Spray the crank and wash as much as the grit away as possible then remove the tape and towels from the crank and clean and wipe the journals again.
Now going by the book, you can insert a compression ring, or both into a cylinder and check the gap. I never had a problem with this and the cylinder tolerances allow .004 anyway, so as long as the gap is not as wide as your pinky or it's touching, don't worry about getting too technical and I doubt you will have a problem unless the rings were screwed up when made. Start with the funny looking "squiggly" oil ring and then roll on the 2 skinny oil rings, one on top and one one bottom with the ring gaps not in line. You need to stagger the gaps in different positions. No need to get precise about this. Use your hand and make sure all 3 oil rings in the bottom grove are inserted correctly and not catching. Now roll on the thicker compression ring to the middle groove noting the marks at the end at the gaps. These should face up. The top ring might have a beveled edge. If it does, the bevel faces up also. Be sure to stagger those rings also.
Rotate the crank so the the journal is at it's lowest point. Lubricate the cylinder walls with engine oil. Insert the piston into the according hole with the arrow on top facing the crank pulley or belt side of the engine. Slide a screwdriver through the wrist pin like so to hold it up...........................
Use a ring compressor and tighten it around the piston making sure you got all the rings.......
Use the back of a hammer to gently tap the piston into the cylinder............
You should actually feel it almost pop when it goes in..........
Now having someone slowly push down on the piston while you are down below guiding the rod to the journal helps. Dab a little assembly lube and spread it like butter on the bearings and take note of the oil holes on the bearings and the line up tabs. Make certain the bearings are in their proper place and seated correctly before you torque the connecting rod caps. After you torque it, rotate the crank by hand at least 2 revolutions. It should rotate very smoothly and not bind anywhere. Repeat this on all cylinders. If you want to "go by the book" use a plastigauge to check bearing tolerances. I use them to light my kerosene heater =)
There is your complete instructions on rebuilding the bottom end. If you are replacing pistons, then you will need access to a press to push out the wrist pins from the connecting rods and precise sized adapters to fit correctly. The connecting rod oil hole should be on the back of the piston with the arrow on the top facing the belt side of the engine.
Hope this help some of you.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Wed Oct 07, 2009 12:59 am
Nice, nice, very nice!
If you soak those pistons in 'Simple Green'
overnight you won't need to clean any carbon out of the ring grooves, because the solvent seems to dissolve it all away.
Also, you won't need to hit the tops up with a wire wheel, but just an old toothbrush.
I'm not sure if the solvent attacks any special piston coatings, but I don't think so.
How about this for an 'Okie Hot Tank':
It's just a 2 liter soda bottle which has been cut about 270 degrees around the top, allowing you to drop the whole assembly in.
Here's a set that sat in a 2 liter soda bottle:
And they never saw anything harsher than a toothbrush to finish them up!!!
JM mentioned the ring gap testing.
Here's a picture of the before:
and during ring end gap measurement:
It can tell you how much life is left on your block.
If you want to go an extra mile, you can do this:
by following the instructions in this thread:
viewtopic.php?f=2&t=40445
One of the nice things about JM is he uses the exact same technique as I do with the wooden handle of the hammer trick:
Again, nice write up!
Might be worth a sticky???
PostPosted: Wed Oct 07, 2009 8:54 am
Very nice guys, very nice - makes me wish the internet had been around when I did my first engine rebuild - 30 plus years ago, all I had to guid me back then was the pictures in my Haynes book.
'93 1.3 Swift GLX
'98 2.0 Grand Vitara
PostPosted: Mon Dec 07, 2009 2:45 am
Thanks for taking the time to write this up.
PostPosted: Mon Dec 07, 2009 8:19 am
Good work on the write-up. A friendly suggestion...you might want to include in your instructions to use something to protect the rod bolts from damaging the crank journal on removal, and assembly...i know some experienced guys will sneak them by with no damage, but it's wise for any with less experience to use the little rod bolt boots, or some small peices of rubber hose
PostPosted: Sat Dec 19, 2009 9:44 am
What grit? And what's a decent price to pay for one?
Thanks for the guide, I'm hoping to rebuild two engines this winter.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Sat Dec 19, 2009 11:57 am
In my opinion the block style hone, is a much better unit that the ball style. Just my opinion.
As for grit, 220, and don't buy the Harbour Frieght/Princess Auto units... :wink:
My cars:
PostPosted: Wed Dec 23, 2009 12:24 pm
I picked up a 240 grit 3" ball hone for $30. I think that's the right one.
PostPosted: Tue Apr 20, 2010 11:25 pm
In the first post it says that this can be done without removing the engine but the instructions have a lot about doing things with the head while it is off.
Can I get into the bottom and replace the rings without removing the engine? I imagine I would not be able to hone the cylinders.
If I just wanted to replace the rings from the bottom. Could that be done and be worthwhile?
The exhaust valves were replaced not too long ago (not by me) but the engine smokes a tiny bit most of the time, and a lot under high RPMs, so I suspect the rings are shot and I would just want to replace them.
1991 Sprint/Metro, G10 3 cyl, 5-speed, 3 door
PostPosted: Wed Apr 21, 2010 12:10 am
Pistons only come out the top. The head has to be removed.
The engine doesn't have to come out of the vehicle though.
- MPGuino
PostPosted: Sun Apr 25, 2010 5:18 am
@ssclown
Great article and pictures! Thanks.
PostPosted: Sun Feb 13, 2011 10:17 pm
youre one good fellow johnny, ive a newb to this rebuilding engine stuff but reading your stuff with great info plus visual aids is top notch and surely will help me understand rebuilding engine and whatnot.... i thank you so much.....
PostPosted: Mon Mar 05, 2012 5:10 pm
Any way the pictures could be fixed on this thread? Does someone still have them?
PostPosted: Mon Mar 05, 2012 5:17 pm
Yo, bro.
I live a few hours away from you and I can see all the pictures in the thread.
Might be time to do a virus scan. =)
PostPosted: Mon Mar 05, 2012 9:49 pm
Looks ok on the east coast too!!
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
