It is currently Sat Feb 24, 2018 10:42 am
PostPosted: Tue Jan 12, 2010 6:03 am
Most of the engine mods relating to intake and exhaust are towards high end torque.
I was annoyed at the low end response of my ride. I researched and found that a longer intake tube and slightly bigger diameter intake pipe just b4 the throttle body shifts my peak torque a bit towards low end, by low end I mean the startup ~ 1200 rpm to 1500 rpm.
I felt good drivability around town, less gear shifts, smooth start up in first gear without even a slight shudder.
Other people may have tried it too, please give your feedback.
Thanks.
Cried for not having a Honda, laughed at Honda not having G13B motor.:ez_pimp:
PostPosted: Tue Jan 12, 2010 8:43 am
picture attached detailing the longer intake tube.
PostPosted: Sun Jan 17, 2010 6:52 am
Longer than what?
All you did was mod it a bit closer to what originally came from the factory. Just think how great it would be if it had been left alone to start with.
PostPosted: Mon Feb 01, 2010 4:42 am
Woodie !
Its 3 inches longer and about 1/4 inches thicker tube than factory. I am buying a Baleno tube and will fit that in reverse as the reverse end is still thicker. Will post pic after doing so.
I keep on experimenting with diff tube sizes and have come to a conclusion that longer tubes with bigger diameter near the throttle body give best throttle response in an NA engine.
PostPosted: Mon Apr 12, 2010 4:25 pm
hey,
i found that just fully taking the air box and assembly off the air filter works great. Because the 93 are carb'd you can put just a normal air filter on it. I found that it greatly improved the acceleration and the torque on the car. Oh and if it comes to any significance adding a 2 1/2 inch exhaust from the cat back greatly improves performance and gas mileage :D
PostPosted: Mon Apr 12, 2010 6:11 pm
darkspecter101 wrote:
hey,
Candidate for 'post of the month'???
PostPosted: Mon Apr 12, 2010 8:13 pm
hey,
I had this argument with my dad for years... Was he surprised when I pulled the injector out... :lol:
My cars:
PostPosted: Mon Apr 12, 2010 8:25 pm
Ok so i retract my previous statement...my bad, anyways as i did say i do just have a regular circle air filter i pulled off my dads old Chevy truck and modified it a little to fit.
PostPosted: Fri Apr 16, 2010 12:02 am
I just showed my neighbor the throttle body and injectors on his 'new carb'd' 1991 sprint tonight, Got his old 88 sprint for free though! didn't even ask for it.
Scott
Its not lag, its suspense...
1987 mk1 T3
