It is currently Thu Jan 18, 2018 2:45 pm
PostPosted: Sat Jan 23, 2010 5:20 pm
hi , does anyone know if they sell just the bearings that go on the trans side of the geo metro drive shaft ???
any help would be greatly appreciated chuck porsh911t@comcast.net
PostPosted: Sat Jan 23, 2010 6:59 pm
usually just replace entire axle assembly,if insde bearings are shot more than likely outside balls are clicking when turned hard,g.m. manual recomends axle replacment rather than repair,try dealership for bearings,most likely more $$$$$$ than a re-man axle....my last axle cost me $30$ after core charge,core charge was $100$ :huh: plus i have lifetime warranty,any problems,they give me another axle for FREE =)
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Sun Jan 24, 2010 6:03 am
i know , but the axles are special cut to fit the mini .so i have the insides of the metro , and the outers are from the mini,
so im just trying to find the bearings.......thanx chuck
PostPosted: Sun Jan 24, 2010 12:03 pm
Are the outers from the mini even the right diameter that the Metro bearing would fit and work?
You could try a junk yard and scavenge the inner bearings.
- MPGuino
PostPosted: Sun Jan 24, 2010 5:27 pm
sorry did not know it was a swap/gender blender,take bearing (needles and cup,race)to a bearing or trannsmission shop,should be able to source something for your conglomeration-good luck!!!! =)
3 tech 6*gear
gti brake swap
