It is currently Wed Jan 17, 2018 12:32 am
PostPosted: Sun Feb 28, 2010 2:43 pm
are the piston rings the same for the 1.3 dohc and 13. sohc?
i'm having a little trouble finding gt rings but no trouble finding the sohc ones.
also what's a good brand, or are they all the same?
thanks in advance.
92 swift ga coverted to gt. always a work in progress
PostPosted: Sun Feb 28, 2010 2:47 pm
They are the same rings. the last gt engine I built I used standard 1.3 rings. works perfectly.
PostPosted: Sun Feb 28, 2010 2:57 pm
super! thanks for the fast reply!
any recomendations on ring brands?
PostPosted: Sun Feb 28, 2010 11:23 pm
i've used all sorts and nvere had an issue. Cheap, expensive, all seemed to work. OIf course dealer is likely the highest in quality and price.
PostPosted: Wed Mar 03, 2010 12:23 am
From the 1991 Swift service manual:
SOHC - top ring plated with hard chromium
DOHC - outer surface of top ring treated with nitriding, 2nd ring plated with chromium
I'm hoping the difference isn't significant, I bought NPR SOHC rings for my DOHC. Made in Japan and very cheap on eBay. :thumbsup:
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Wed Mar 03, 2010 1:58 am
i guess that would be the advantage to the dealer rings. The gt engine received special treatment on everything!
PostPosted: Wed Mar 03, 2010 10:47 am
well that gives me something to think about.
might as well shell out the big bucks
PostPosted: Thu Mar 11, 2010 7:24 pm
I recently got Genuine Suzuki rings for my 1.0. All rings are coated except for the top ones. I got them from the local Suzuki dealer and they were very expensive :shock: Next time I'll definitely go for something cheaper..
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Fri Mar 12, 2010 3:57 pm
I ended up using the parts dinosaur to get my rings. The SGP ones are 50 dollars for one cylinder! :( :(
The parts dinosaur were only like 35 dollars and they are made by enginetech.
Hopefully they work well, I'll see in a few weeks :D
