It is currently Tue Feb 20, 2018 2:44 pm
 Post subject: Pcm diag 101
PostPosted: Wed Aug 25, 2010 9:18 pm
Diagnostic flash code procedure 1994 geo metro? I need the jumper pin location in the DLC. I know on GM products it is the #1 and#2 top pins. Do I jumper both #1 upper and lower row on a geo to get a flash code?
 Post subject: Re: Pcm diag 101
PostPosted: Wed Aug 25, 2010 9:54 pm
It's not a GM product, so the pins are different, look under the hood the jumper pins should be listed on the sticker.
You will either have a six pin of a four pin block. There is also plugging a fuse into the fuse block.
My cars:
