It is currently Sat Jan 20, 2018 8:10 pm
 Post subject: MK1 Suzuki Swift GTI ECU
PostPosted: Wed Sep 08, 2010 2:57 pm
Does anyone have a pin out for a MK1 ECU I have searched the net and I can only find a MK2 one.
PostPosted: Wed Sep 08, 2010 3:24 pm
The Smuggler
Have you tried redlineGTi?
We never got the MK1 GTi over here in NA
And I love this one!
PostPosted: Wed Sep 08, 2010 3:51 pm
Yes I have seems to have people asking the same question but no answer
PostPosted: Wed Sep 08, 2010 4:57 pm
I may be able to help out a fellow Kiwi... I bought a genuine Suzuki workshop manual off the net for a Mk 1. I gave it to a mate of mine who has a Barina GTi. I'll ring him and get him to check if it has the ECU pin outs...
PostPosted: Wed Sep 08, 2010 4:59 pm
Great Thanks
PostPosted: Wed Sep 08, 2010 8:08 pm
I am going over to photocopy the relevant pages soon. I'll post the pin outs here. I'll post the photocopied section to you if you pm me your address...
PostPosted: Wed Sep 08, 2010 10:53 pm
There are three couplers - a 24 pin, 18 pin and 10 pin.
The 24 pin one is labelled like this
B D F H J L N P R T V X
A C E G I J K M O S U W
A-power
B-earth
C-power
D-earth
E-power source for air flow sensor
F-power source for back up circuit
G-power source for throttle sensor
H-earth for sensors
I-earth for air flow sensor
J-electric load switch
K-air flow sensor
L-blank
M-water tem sensor
N-blank
O-oxygen sensor (if equipped)
P-blank
Q-throttle sensor
R-idle switch of throttle sensor
S-blank
T-diagnosis start switch (coulper)
U-blank
V-earth for selection
W-ignition pulse
X-blank
The 18 pin couple is labelled like this
2B 2D 2F 2H 2J 2L 2N 2P 2R
2A 2C 2E 2G 2I 2K 2M 2O 2Q
2A-selection
2B-selection
2C-check engine lamp
2D-blank
2E-VSV for idle up
2F-selection
2G-blank
2H-power source for fuel pump relay
2I-TWSV for ignition advance
2J-TWSV for EGR valve (if equipped)
2K,2L,2M-blank
2N-earth
2O-power source for main relay
2P-earth for injector
2Q-power source for injector
2R-earth for injector
The 10 pin coupler is labelled like this
3B 3D 3F 3H 3J
3A 3C 3E 3G 3I
3A-engine start switch
3B-power source for injector
3C-1 injector +
3D-1 injector -
3E-2 injector +
3F-2 injector-
3G-3 injector +
3H-3 injector-
3I-4 injector +
3J-4 injector -
PostPosted: Wed Sep 08, 2010 11:11 pm
Thanks so much thats a great help & thanks for the speedy reply.
