It is currently Thu Feb 22, 2018 6:15 pm
PostPosted: Sun Apr 24, 2011 9:56 pm
hello every one I bought recently a suzuki forsa 1986, and i am having problems with my fuel economy, bc a whole tank its only lasting like 2 days, there is an light on the dash board that keeps blinking, that says sensor, could that be the problem? what does the light means?, or is there a way to adjust my carburator settings? would appretiate all help. THANK!
PostPosted: Sun Apr 24, 2011 11:27 pm
It should be a 1.0L.
That year model had a sensor light which blinked, telling you that one of your sensors is unplugged.
Do you have an O2 sensor? Is it plugged in?
Later model years would blink and tell you exactly which sensor wasn't working.
Unfortunately, you'll have to check them all.
If you need more help, post some detailed pictures of your engine compartment, including wiring and vacuum routing.
It could be something as simple as a loose connection, or the switch up by the fuse box in the wrong position.
Hope this helps.
