It is currently Sun Feb 25, 2018 6:54 pm
PostPosted: Wed Jun 08, 2011 2:03 am
Dear Members,
I had gone through viewtopic.php?t=17205 where specified the repair of crank window fairly.I was in long search on internet of a picture of crank window regulator of my Suzuki Swift, it never happened.At last i found one from a workshop.I took the photographs to compare it with any picture matches with it.Again no hope.BUT when i saw the above thread in teamswift, i became so happy, why because window regulator shown there is perfectly similar with mine!.Still one thing to get; where i can found the window motor suits that crank?please help me.I attached those photographs here;
PostPosted: Wed Jun 08, 2011 9:32 am
Most regulators like that were designed for manual operation in North America.
You can buy the motor from this vendor:
carspares-direct on Ebay.
They have one motor currently listed:
Item #150577912384
See if this link will get you there:
http://cgi.ebay.com/150577912384?ru=htt ... 3D1&_rdc=1
You'll need to contact them first for shipping and specific application issues.
Hope this helps.
PostPosted: Thu Jun 09, 2011 6:21 am
Hi Phil,
Will item #150577912384 of carsparesdirect ebay shop suit for window winder showed on my attachment?.when i contacted company-carsparesdirect, replied that it was no longer available.Please suggest more.
PostPosted: Thu Jun 09, 2011 7:38 am
ansariatteamswift wrote:
Hi Phil,
Here are two 'universal' electric motors for $138
Item: 370450083238
These are not exact replacements; but you can contact the company and inform them of your year make and model.
Perhaps they have something which is correct.
If you are in a tight budget, you can use a Dorman
Item number: 370474183858
and a pair, which cost less than $46 shipped in the USA
Item number: 180678485185
Notice that there is no difference between the right and left.
From time to time, universal electric conversion kits are available on Ebay, so monitor the site for several months to obtain your best value.
Make sure to post pictures of your vehicle if you are going to be needing detailed help from the membership here on Teamswift. Hope this helps and welcome.
PostPosted: Thu Jun 09, 2011 1:24 pm
Hi Phil,
Why is the specific one not available?The vehicle is very new.Picture of my vehicle is attached here.If you could inform me that whether the model is marketed in north America?If it's there why is not a genuine replacement available?Could you please list me some power window motor manufactures in your state?
PostPosted: Thu Jun 09, 2011 11:19 pm
With a car that new you should just go to the dealer.
PostPosted: Thu Jun 09, 2011 11:56 pm
Thanks for the picture.
Here are two more items to check:
Item number: 320698955346
Item number: 150570872211
Again, you can contact those vendors directly.
The vehicle you own is known as the SX4 here in North America.
Top Down mentions the dealer; you can probably get a replacement for less in India's Suzuki dealerships.
It appears you are writing from India.
Be thankful you don't need a distributor O-ring for a Jaguar -
Item number: 150598929857
