It is currently Thu Jan 18, 2018 2:44 am
 Post subject: G13A and G13B Block
PostPosted: Mon Feb 13, 2012 3:59 pm
Hi Does any one know if the G13A block is the same as the G13B block ,i konw the 13A engine is a 8 valve and the 13B is a 16 valve engine but that apart is the block the same . I have a G13b with a cracked block and i can lay my hands on g13A blocks at low money .any one help ? :shock:
 Post subject: Re: G13A and G13B Block
PostPosted: Tue Feb 14, 2012 1:43 am
Probably not the right place to ask as there are very few g13a blocks in North America, the redlinegti boys will have more idea.
I theory they should be the same as the extra capacity is made with the crank, g13a is 1324cc with 77mm stroke and g13b is 1298 with 75.5mm stroke, the g13a will only have the castings for the early engine mount setup so you could use one in a mk1gti but not in a mk2/3, you need to find a g13b sohc block from a mk2/3 swift/justy if you want a low stressed virgin block.
PostPosted: Tue Feb 14, 2012 2:26 pm
hi thanks for the infomation :wink:
