It is currently Sun Feb 18, 2018 5:50 pm
PostPosted: Wed Mar 28, 2012 3:00 pm
I looked around and didn't see a DIY clutch thread.
I am thinking of doing the clutch on my 94 swift gt
thanks!
CheerS!
___________________
89 Swift gti
PostPosted: Wed Mar 28, 2012 4:50 pm
thanks!
CheerS!
It's all here:
http://www.teamswift.net/viewtopic.php?f=9&t=32541
and there are a few illustrated threads, too.
