It is currently Mon Feb 19, 2018 3:10 am
PostPosted: Fri Sep 20, 2013 12:34 am
I have a 93 swift no spark or power to fuel pump changed fuse box under dash and in engine comp fuel pump relays no luck is there a simple solution tried a different computer nothing.
Thanks
PostPosted: Wed Oct 23, 2013 4:22 pm
I had a same problem. Check the connectors, mine had fallen of. :)
It's not much but maybe it helps. :)
PostPosted: Wed Oct 23, 2013 6:49 pm
Check your grounds.
PostPosted: Wed Oct 23, 2013 7:03 pm
top down@-40 wrote:
Check your grounds.
+1 for check your grounds!
