It is currently Sat Feb 17, 2018 10:27 pm
 Post subject: Is my swift a 1.0?
PostPosted: Wed Jun 04, 2014 1:44 pm
Hi there, recently bought a 1999 Swift Sky (3 door)..has a gti bodykit on it and original semi-bucket seats. As far as i am aware it is a 1.0 but kinda having doubts due to it being pretty quick and loud.. I was just wondering if anyone with the same model has noticed if they're fast and loud like mine or do I possibly have a 1.3 or something?? :huh: Not sure if it matters but it has twin exhaust too. Cheers, Jack
 Post subject: Re: Is my swift a 1.0?
PostPosted: Wed Jun 04, 2014 2:32 pm
Does it have 3 ignition wires or 4
___________________
89 Swift gti
PostPosted: Wed Jun 04, 2014 2:54 pm
Well, Suzuki in Pakistan put 1.0L four cylinders in these cars too, but I have no idea if those motors were used anywhere else. I am intrigued with this "Sky Edition" stuff. Found these pics, which show a SOHC 1.3:
http://www.caricle.co.uk/detail/Used-1999-Suzuki-Swift/JoTxSooZSmSosPoPmsT.html
PostPosted: Wed Jun 04, 2014 5:21 pm
Yep. I am clueless on this; sense Suzuki after 94 went all out econo in U.S. :huh:
PostPosted: Wed Jun 04, 2014 7:06 pm
Take a look at the block in the front of the engine at the gearbox side. The engine displacement and block code should be stamped in that corner.
image_id: 22616
1993 Swift Gti
PostPosted: Thu Jun 05, 2014 4:24 pm
Guys is there any way I can find out what litre my car is? On the cars registration it says its a 1.0 but I just have a feeling its not. Any help is appreciated.. I uploaded some pics so you can judge for yourself and, well, just because I like to show it off hehe :mrgreen:
PostPosted: Thu Jun 05, 2014 4:25 pm
where would i find them?
PostPosted: Thu Jun 05, 2014 4:27 pm
Note: It is the Sky edition, the only reason it is black is because it was sprayed
PostPosted: Thu Jun 05, 2014 4:54 pm
That's a 1.0L
PostPosted: Thu Jun 05, 2014 5:15 pm
top down@-40 wrote:
That's a 1.0L
How can you tell? :?
PostPosted: Thu Jun 05, 2014 6:49 pm
3 spark plug wires in the front of the engine.
Someone may have installed an aftermarket cam in it to increase power.
PostPosted: Fri Jun 06, 2014 4:29 am
Just because the muffler has 2 outlets doesn't mean it has twin exhaust. Look ahead of the muffler and I'll bet there is only 1 pipe.
PostPosted: Fri Jun 06, 2014 4:06 pm
Senior Member
You may have to explain this a bit further to Jack... Jack, there are two pipes coming out of the muffler, but one may just be for show. One may just be welded to the outside of the muffler case. You can check this by looking into the pipes and see if they go further than the case. Or stick a screwdriver down them and see if one stops at the case.
PostPosted: Fri Jun 06, 2014 10:45 pm
that's most definitely a g10 3 cylinder.
the twin spout rear box is probably a gt muffler that was used as a replacement.
