It is currently Sun Feb 25, 2018 4:04 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 12, 2007 7:17 am
Thanx, that makes sense, there were several options that i could see, just wanted a 'tried and proven' application. I really appreciate your response.
MOST people don't know what they're doing
and some of them are REALLY good at it!
1992 GEO Metro Vert
1988 Sprint Turbo 5sp ready for restoration
1995 GEO Metro 2dr auto
1995 Toyota T-100 SR5 4X4
PostPosted: Tue Mar 13, 2007 3:35 pm
Cleaned mine today, Car idles and pulls A LOT smoother, its nearly not as rough, The longer diode had white crap on it, the shorter one had some black crap, cleaned it off, let the bottom part soak in some alcohol, then took a q-tip and softly cleaned everything off, runs great now
-Amer
PostPosted: Thu Mar 15, 2007 5:05 am
UPDATE:
My car used to idle at 1500rpm and the rare time it would drop down to 1100,
now it idles at 1100 all the time
so cleaning the maf fixed that too
PostPosted: Sun Oct 26, 2008 12:29 pm
Do you have any tips on clean the MAP "not MAF" sensor on a 1999 Suzuki Swift? I tried spraying some MAF sensor cleaner into the little inlet to solve my erratic idle problem, but didnt do anything. Is there a better way of cleaning them?
PostPosted: Wed Jul 22, 2009 9:05 pm
well here's my opinion, carb cleaners or contact cleaners are good for other applications, 'couse they are axtremly cold and the cold couses little cracks in the resistences, and the readings will be poor.
i used diesel, it's warm and really make a deep clean, i have tried both, the result it's better using diesel, with a little pencil brush.
PostPosted: Wed Jul 22, 2009 10:47 pm
No MAF on the 4 cylinder cars after '98.
Suzuki upgraded them to the far more efficient, precise, quicker, just plain better MAP sensor.
MAP = Manifold Absolute Pressure
My cars:
PostPosted: Fri Jan 21, 2011 10:52 am
hi guys ! im kinda new around here.. well i got a 88 gti. missing problem at idle. i tried every thing like cleaning maf and even changing injectors but still it gives me problem at low rpm. like its just pulls back at low speed like while im crusing at 60 to 80 kmph.
PostPosted: Sat Aug 24, 2013 12:07 pm
Can some one post up some new pics on how to clean the airflow meter for a gt? And I heard the position or the sensor, either top bottom or on the side the position is important. Is this true?
