It is currently Wed Jan 17, 2018 2:42 am
PostPosted: Tue Mar 22, 2005 10:07 pm
compression test sounds like a good idea. then when the comp. checks out put a timing light on it.that will varify your timing belt. if you have to crank the dist. around (where it hasnt been before)to get the timing on , your off a tooth.
Dattman wrote:
