It is currently Sun Jan 21, 2018 11:59 am
 Post subject: dodgy backend
PostPosted: Wed Dec 28, 2005 4:23 pm
im having a problem wit my 1990 swift gti. when going over bumps i can feel the backend kicking out. i have adjusted the rear caster as close into spec as i can, it is lowered 40mm and its got powerflex polybushes on the rear.
can anyone suggest anything else i can do??
PostPosted: Wed Dec 28, 2005 4:42 pm
AFAIK - caster is not adjustable on these cars, at either end. The only adjustment possible with the standard suspension is toe-in/out.
I don't think camber is a problem on the back end of these cars with lowered suspension, so I'm guessing what you need is a good four wheel alignment job.
PostPosted: Wed Dec 28, 2005 7:48 pm
Those links adjust toe in/out.
PostPosted: Wed Dec 28, 2005 11:06 pm
Jeez Woodie.You have my two dream cars.
S.U.V.'s suck (up a lot of gas)
PostPosted: Thu Dec 29, 2005 4:08 am
I had this problem back about a month ago with my wife's vert. it was a bad strut. really wore the tire on one side with lotsa camber wear. I replaced the strut, and everything is back to normal again, driving straight without swaying or kicking out and the back end swinging around.
I got the struts offa ebay, really cheap and they ship fast. search under parts & accessories for "metro struts". it was oem suzuki/gm strut.
