It is currently Fri Feb 23, 2018 11:58 am
 Post subject: Torque Specs
PostPosted: Wed Jul 16, 2008 3:20 pm
A thread for torque specs....
Here are the listings for all Intake and Exhaust Manifolds and Heads in Engines thru 2005:
If your torque setting isn't in the list, look it up, and add it.
PostPosted: Thu Jul 17, 2008 7:06 pm
Wheels, Sprint, & Metro 1985 thru 2001:
Drum spindle nut
Castellated nut: 58 to 86 Ft-lbs
Staked nut: 129 Ft-lbs
Drive axle to hub nut
Castellated nut: 108.5 to 195.0 Ft-lbs
Hayne's Repair Manual page 8-1
"If nobody comes down here and buys a car in the next hour, I'm gonna club this baby seal!!! That's right! I'm gonna club this seal to make a better deal! You know I'll do it!!!"
PostPosted: Fri Sep 26, 2008 9:38 am
PostPosted: Sun Sep 28, 2008 8:29 am
MK2 front:
stabilizer bar bracket bolts 13-2l pounds
stabilizer bar link to control arm nut 13-21
stabilizer bar to link ball joint nut 30-44
 Post subject: Re: Torque Specs
PostPosted: Tue Mar 31, 2015 11:21 pm
Water Pump Pulley Bolts
Timing Belt Cover Bolts
Crankshaft Pulley Bolt
Timing Belt Tensioner Bolt and Stud
Torques:
(Images in first post of thread lost in server move.)
