It is currently Tue Jan 16, 2018 4:20 pm
PostPosted: Fri Oct 22, 2010 8:29 pm
Hi
I live in Australia. I have a 1985 Suzuki Swift GL, 5 speed. It won't start unless the accelerator pedal is depressed, and when the revs drop below a point, it dies. I suspect the carburetor has debris in it, and I have been looking for a rebuild kit. A previous owner has removed the egr hose so now the egr doesn't do anything.. not sure if that is important...
Anyway, the carburetor is an AISAN, with an aluminium tab with 82070 screwed onto it. The accelerator pump is also not functioning.
Where can I get a carburetor rebuild kits (gaskets, seals and all) for this model of carburetor and seals for the accelerator pump (or a whole new pump)
Thanks in advance
PostPosted: Fri Oct 22, 2010 8:52 pm
What's your budget for the repairs?
PostPosted: Fri Oct 22, 2010 11:26 pm
Not really sure, about $200. The car was $350, so I probably don't want to spend more than $300.
thanks 8)
PostPosted: Sat Oct 23, 2010 8:43 am
You can probably get it running like new for that budget.
Post a picture of it, and see if this helps:
http://s145.photobucket.com/albums/r211 ... in%20Carb/
PostPosted: Mon Oct 25, 2010 2:53 am
Ok, here are some images of the carburetor. I should probably add that one of the previous owners has removed a few tubes here and there, like the big one coming off the egr, but they didn't seem to affect the car too much, until recently, when it started playing up. Also, a manual chocke has been fitted at some point in this car's past. Anyway, I got a few snaps of the carbi.
CIRCLED: Missing vacuum hose
CIRCLED: Manual choke
CIRCLED: Missing Vacuum hose
CIRCLED: missing Vacuum hose, and the second circle is doubled over
I'm pretty sure it's the one in those links. The diagram is good.
Are any of these fatal issues?
Where can you get rebuild kits and accelerator pump seals for this beast? I have looked everywhere, but I can't find anything.
Thanks
PostPosted: Tue Jan 11, 2011 5:37 am
Hi,
Yeh i have just been told that i will need to have the carby done ... cause they couldnt adjust the idle all other ways... idle is high.... so when i turn it off it runs on a bit.... and i was quoted $300 to get it done ... at Profix ... I am going to ask around to see if someone can do it cheaper but i believe that they would have to send the carby off to be rebuilt or whatever...
I have a suzuki Swift ga 1991 manual... bought it a coupla days ago... thinking that the idle could be fixed with a service and a tune/timing... but bugga it... its the carby... :/
Lubluz
PostPosted: Thu Jan 13, 2011 5:26 am
Right... i just phoned another mechanic and he reckons that going through all the bs of getting the carby rebuilt etc is wrong.... firstly he reckons that it could be due to the car not warming up... so there might be some crap in it or in the hoses...or something..so he said he would flush it all out first and see if that works..then he would go to a wreckers and get another carby and put that one in for much less $$$$$$ :)
Lubluz
PostPosted: Wed Jun 24, 2015 11:30 pm
Hey guys I'm having similar problems with my carb. As well I have a 93 swift 4 cylinder g13 b engine.. The car looses power when going up hill and whenever I. Start it in the morning its bill up and then just dies..the thing is I don't know the type or model carb that I have so I am seeking some help as well.. I will post pics below...please can someone help me identify the type of carb...or give me some pointers as whhat to look for to identify..Thanks
