It is currently Mon Feb 19, 2018 7:35 pm
 Post subject: JB weld a spark plug?
PostPosted: Sun Oct 24, 2010 1:46 am
One of my spark plug threads is stripped in my MK1 head. I am awaiting my spare head from the machine shop but wont have time or help to install it for a couple weeks.... I was thinking I could maybe JB weld the plug in for the time being. Will this possibly work or cause a bigger problem?
1987 Turbo Sprint
PostPosted: Sun Oct 24, 2010 10:22 am
Yeah... No...
Go out and buy a spark plug thread repair kit. Do it right or don't do it at all. Princess Auto sells em for $20 or so.
My cars:
PostPosted: Sun Oct 24, 2010 12:20 pm
How does this ''repair kit'' work so that you don't get anything down on top of the piston?
PostPosted: Sun Oct 24, 2010 1:16 pm
PostPosted: Sun Oct 24, 2010 4:38 pm
Are those kits reliable? Still seams like you would get all kinds of shavings in the block to me?
1987 Turbo Sprint
PostPosted: Sun Oct 24, 2010 5:24 pm
A lot of people have used them with great results.
I'm thinking the normal flow might carry most loose metal shavings out the exhaust pipe, especially at a higher rpm.
Have you asked a machinist, or son of one? They'd probably be the best source of info on the subject.
:wink: :wink: :wink:
PostPosted: Sun Oct 24, 2010 5:53 pm
Use cutting oil on the thread cutter, and the cutter itself will hold onto 90+% of the shavings. You will do far more damage to your engine trying to epoxy the spark plug into place.
My cars:
PostPosted: Sun Oct 24, 2010 7:33 pm
The Smuggler
Helicoil Makes a top of the line spark plug repair kit, they work excellent.
Lordco sells them
As his head is already off should be no issue repairing the problem properly.
I would not use JB weld, do it right.
And I love this one!
PostPosted: Sun Oct 24, 2010 8:03 pm
JB weld is for rookies. Weld it :lol:
