It is currently Sun Feb 18, 2018 6:07 am
 Post subject: bad wheel calibration??
PostPosted: Tue Nov 16, 2010 6:36 pm
i have an issue i got 13inch wheel on my mk1 the original rims are 12inch so my speedometer is not pointing the right speed.....any one know how to fix this???please any advise is welcome
suzuki forsa 1985 (SA310) with g13bb swap>>SOLD!
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Tue Nov 16, 2010 6:52 pm
it's not so much an issue with the diameter of the rim as it is the overall diameter of the tire on the rim. look at a lower profile 13" tire, one that has a diameter closer to the stock tire.
PostPosted: Tue Nov 16, 2010 6:57 pm
yes i was thinking about that but i really like the wider tires and yes i know is not the wide that matter but the tires are almost new so i wont change them until is time......but is there anyway at all to calibrate this? or i will have to wait and buy newer tires?? thanks man
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Tue Nov 16, 2010 11:42 pm
You can change the gear in the trans where the spedo cable
screws into the trans. When I bought my blue 85 chevy sprint, it had mag 13" rims and wide tires on it... I put in a tach and based on the RPM, I calculated the MPH. A few months after I bought the car, the front wheel bearings started to howl. I had to change the bearings because the rims were wider than the stock ones. I sold the mags and tires for $300 and bought the correct, 12" tires, rims and had enough left over to replace the cracked windshield.
Hope this helps you even if just for information
Dale
PostPosted: Fri May 13, 2016 3:31 pm
So I can take the speedo drive out of a 1995 metro tranny and put it in my 91 fly with metro 13's on it and the speedo will be correct?
PostPosted: Fri May 13, 2016 4:05 pm
Yes, you can get different geared speedometer end that go into the transmission. I don't remember the correct one's to use as it's been a while, but I do know GeoMetroForum has the right information for the correct way to do it. The problem is finding the correct gear. Perhaps the 'parts wanted'? Good luck.
PostPosted: Fri May 13, 2016 8:49 pm
I'm just going to look for a 95 or newer metro and see how it goes. As long as I don't have to go into the transmission it should be a snap just changing the bullets. Thank you for your reply.
