It is currently Fri Feb 23, 2018 5:30 am
PostPosted: Wed Feb 26, 2014 1:00 pm
I have a swift GTi without powersteering, I would like to know if I can easily convert it to powersteering by using the 4wd steering rack.... its all that available in my country
PostPosted: Sat Jun 20, 2015 2:48 pm
Not exactely, tie rod are different 8you need to use the gti ones), oil reservoir is different and if you don't want to relocate you have to use the gti one with its hoses. Steering pinion is different and even the steering joint is longer in the gti. I'm doing the same conversion, Maybe the next month I'll have finished so I'll be able to list each modification is needed. By the way my gti is 1990 (mk2).
Greetings from italy
Pietro
PostPosted: Sat Aug 22, 2015 4:50 pm
Good news, you can use aftermarket steering rack (if you go lhd I listed manufacturer and part number below).
Pipe lines for lhd (gti) are available in europe just from one distributor and I let you now where as well as soon as I verify availability.
Finally the pump is same as 4wd.
Steering joint is supposed to be allright the one from gti rhd with p/s, not sure though.
SUZUKI 4858060E10
SUZUKI 4858060E11
SUZUKI 4851086000
SPIDAN 0052104
LIZARTE 01874500
CARDONE 26G82113
CARDONE 26G82115
TRISCAN 851069400
DA SILVA DA2538
DA SILVA DM2376
DELCO REMY DSR1071L
DELCO REMY DSR809L
ERA BENELUX SR22105
TTV TSR809L
Pietro
PostPosted: Sat Aug 22, 2015 4:54 pm
Thanks for sharing.
