It is currently Sat Feb 24, 2018 9:55 am
 Post subject: compression
PostPosted: Wed Mar 11, 2015 8:10 pm
Hi all, have a strange problem on my 1992 GT, did a compression test and 3 of the cylinders came out at 220 psi wet, dry was 200,
the last one dry was 220 and wet 250 i am very confuse has any one else ran into this? another thing is that cylinder has a dead miss
at idle all the way up to speed, any help would be greatly appreciated
Thanks
 Post subject: Re: compression
PostPosted: Wed Mar 11, 2015 8:54 pm
bad head gasket.
PostPosted: Wed Mar 11, 2015 9:35 pm
Headgasket?
Maybe--I would have guessed a compression loss in one piston instead of a spike for that diagnosis, but maybe I am missing something.
I am envious of your compression numbers. That must be a very low miles motor :mrgreen:
I'm down to 185 dry all across, but last time I noticed something like this was when I diagnosed a clogged fuel injector--maybe carbon in there? I my case I was 190-200, then #3 spiked at 220.
Anyway, I fixed the injector and have run many miles since. I have lost a little across the board, but now I am at 185 even.
PostPosted: Thu Mar 12, 2015 3:33 pm
Make love, not moderators
I'd say you have a bad fuel injector in that high cylinder.
Fuel washes some of the oil away from the rings which lowers your compression. If your not getting any into the cylinder then it would explain the higher number and the miss firing.
PostPosted: Thu Mar 12, 2015 6:04 pm
thanks for all the input came find out it was a injector changed it and all is well thanks guys
