It is currently Fri Feb 23, 2018 11:57 pm
 Post subject: SWIFT gti problem
PostPosted: Tue Mar 24, 2015 2:05 pm
Hello swift people :)
Who know what is the problem ? :cry: Pleas help me !
https://www.youtube.com/watch?v=GCDTNVHQXlY
 Post subject: Re: SWIFT gti problem
PostPosted: Tue Mar 24, 2015 2:26 pm
you clearly have a check engine light. to read the cel codes you insert a spare fuse into the raised diagnostic slot on the fuse panel under the dash.
if your car still has the plastic cover over the fuses you insert the spare fuse through the only slots in the cover to activate the diagnostic read out.
with the ignition key off, you insert the fuse and turn the ignition to the run position without cranking the starter. read and record the series of flashes observed on the check engine light in the upper left position of the instrument cluster.
as an example, one flash with a pause followed by 2 flashes would indicate 12, or the code for everything being correct. you can find the corresponding code from a list that can be acquired on the internet under a search for "suzuki codes." be sure that you look for the codes for the gt dohc g13b engine.
my initial thought after watching your short video is that you have a problem with the maf wiring or the maf itself. i have encountered the same type of problem and fixed it by something as simple as using an 02 sensor safe solvent to clear oil and debris from the maf's sensor wires. i have run into the same type of no start situation where the maf wiring connector was wet or corroded.
insert the spare fuse into the diagnostics switch port, observe the flashes, and post them here an we can look up the code for you. :wink:
PostPosted: Tue Mar 24, 2015 2:34 pm
thanks , but this i already do , and i have 1 and 4 check light this is code no.14
PostPosted: Tue Mar 24, 2015 3:10 pm
and sorry for my bad english :lol:
PostPosted: Tue Mar 24, 2015 3:43 pm
your english is fine. i hardly speak a bit of a second language so you have my respect.
14 is the engine coolant temp sensor failure code. replace the clt sensor.
viewtopic.php?f=2&t=43952
the engine coolant temperature sensor sets up the cold start fuel enrichment trim on the injection process. it also allows the ecu to tip over into closed loop operation once the engine's nominal operating temperature is attained.
that is the place to begin your troubleshooting. :wink:
PostPosted: Wed Mar 25, 2015 12:25 am
Code 14
1 flash, pause, 4 flashes
Coolant temperature sensor signal indicates a temperature of over 284° F for 4 seconds after the engine had been running for at least 10 secondsCoolant Sensor Circuit (high temperature) If the engine is experiencing overheating problems, have those fixed before continuing. Check all wiring and connectors associated with the coolant temperature sensor. Replace the Coolant temperature sensor.
But here write ...for 4 seconds aster the engine had been running for at least 10 second ... ?? but my swift engine dont work 4 second or 10 !
Can you send me pictures of this sensor ?
PostPosted: Wed Mar 25, 2015 7:54 am
what we mean ?
PostPosted: Wed Mar 25, 2015 12:34 pm
pleas help me ! :cry: :cry:
PostPosted: Wed Mar 25, 2015 2:22 pm
the sensor under the blue connector on upper part of this picture
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Wed Mar 25, 2015 4:34 pm
but i dont't have this sensro under blue senzor ...i have only this blue senor .. but how ?
I have only this sensor here
PostPosted: Wed Mar 25, 2015 4:37 pm
Make love, not moderators
The picture is wrong.
The blue sensor is the one you need to check.
PostPosted: Wed Mar 25, 2015 4:40 pm
ok , thanks , i buy new sensro tomorrow and try it , Who knows what may still wrong ?
PostPosted: Wed Mar 25, 2015 6:57 pm
when i look at your picture, i see the brown connector for the ecu's coolant sensor. it's located right next to the single connection temp sensor that operates the dash gauge. in your picture the connector is unplugged from the sensor.
the temp sensor located forward and higher up on the head is the cooling fan switch. ;)
PostPosted: Wed Mar 25, 2015 7:04 pm
Actually T3 that brown sensor is what turns on the fan motor.
Blue is for the ECU, brown for the rad fan, and there is a little brass sensor threaded into the t-stat housing that does the temp gauge.
PostPosted: Wed Mar 25, 2015 7:05 pm
sorry for the picture, what i mean is under the connector , the sensor itself, not in the circle (this picture was borrow from another sensor thread) sorry for not helping you :lol:
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Wed Mar 25, 2015 9:17 pm
damn it! i collected the wrong darned sensor as my spare.
thanks for getting me straight!
i think i may have been thinking of the g10 sensor set where the yellow sensor next to the brass single pin sensor is the ecu's clt.
another senior moment. :blackeye:
PostPosted: Thu Mar 26, 2015 1:55 am
can someon send me picture which sensor i must buy ?
PostPosted: Sat Mar 28, 2015 5:23 am
today i'll check all cable and sensor , and again does not work , today ill buy on ebay new temperature blue sensor , and wi will see when i replace it ;)... today i found this on my swift :evil: Who knows where the water gets inside?
PostPosted: Wed Apr 01, 2015 12:56 am
why swift don't running on idle position ? :huh:
PostPosted: Thu Apr 09, 2015 4:07 am
i replace the blue temperature sensor .... then i check diagnostic and i have code 12, then i try start engine and from exhauts only baaannggg ( burst ) what is here problem ?
PostPosted: Thu Apr 09, 2015 11:09 am
pleas ... help !!! i really need help
PostPosted: Tue Aug 04, 2015 6:55 am
swift already dont working .... he start for 1 second and then he stop working... i replace new all electronic... nev Fuel rail ramp, new injectorc, new MAF senzor, new thoortle bodies... al this is new but swift already dont working... who knows what can be problem here ?
PostPosted: Wed Aug 12, 2015 10:40 am
who know ? is anybody already have the same problem ?
