It is currently Tue Feb 20, 2018 6:11 pm
PostPosted: Tue May 05, 2015 1:20 pm
Good day, everyone. I'm doing the turbo motor+ convertible swap. I went to order a timing set and I was Asked for a digit out of the Vin, except I didn't get the car the G10T came out of. It's the late motor with the Turbo script on the valve cover. Is a belt a belt?
PostPosted: Tue May 05, 2015 2:39 pm
what year of t3? mk 1 or 2? all g10 motors from 89-94 same belt. later belts have round teeth, earlier have square teeth. not sure on 88 and earlier, I think those are square as well.
you throw the word ''turbo'' at them and they get confused
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Tue May 05, 2015 4:47 pm
It's a 2nd gen motor out of a Firefly.
PostPosted: Tue May 05, 2015 5:50 pm
aside from the fuel system, cylinder head , internals, (the block has a port for the turbo oil return line) and valve cover, they use a lot of the same parts as a n/a g10..
order parts for a 91 firefly, sprint or metro, with a 1 liter. or just order parts for your vert sans turbo. the vert has the same brakes as a turbo, but the parts counter gets confused when I try to order parts for my t3 car....so I tell them its a metro lsi vert, but but but sir those parts wont fit....exact same parts, different application...
3 tech 6*gear
gti brake swap
