It is currently Sun Feb 18, 2018 5:20 pm
 Post subject: Warped header flange
PostPosted: Sat May 23, 2015 4:52 am
Fabricated my own exhaust manifold for the K03 turbo. After fabrication I sanded and filed the surface flat. Now it warped on me. There's plenty of material to true it again but I was wondering if cutting the flange between the exhaust ports would help in the future.
 Post subject: Re: Warped header flange
PostPosted: Sat May 23, 2015 4:53 am
PostPosted: Sat May 23, 2015 4:57 am
PostPosted: Sat May 23, 2015 4:59 am
PostPosted: Sat May 23, 2015 12:51 pm
That used to be standard fix for Mitsubishi Starion factory exhaust manifold that would warp and pull the studs out of the head. I don't see why it would not work for you?
PostPosted: Sat May 23, 2015 1:44 pm
another helpful practice is to saw cut the flange to the stud mounting holes. ;)
PostPosted: Sun May 24, 2015 1:41 am
Thank you I will do both suggestions prior to surfacing it. At least it's thick enough to do that. The first one I made ended up too thin after surfacing it and I was not looking forward to making a third one.
Thanks again Edd
PostPosted: Sun May 24, 2015 5:49 pm
Got it done. As I was making the first cross cut it bound on the blade and flattened out for the most part when cut. Still trued it a little although it didn't take a lot. Any suggestions or comments on ceramic coating? fiberglass in my hands and arms is getting old. Thanks for you're suggestions
PostPosted: Sun May 24, 2015 6:13 pm
