It is currently Sat Feb 17, 2018 9:51 pm
 Post subject: A/C brackets
PostPosted: Mon Jun 15, 2015 8:25 am
Will a 1.3L A/C compressor mounting bracket fit on a 1.0L engine?
Fainya
 Post subject: Re: A/C brackets
PostPosted: Mon Jun 15, 2015 2:07 pm
Compressor is the same for a MK2/3, but brackets are different. Also 1.3 uses an additional brace bracket.
Images:
Geo Metro 1.0 PN 96061175
Suzuki Swift 1.3 PN 9511164B10
PostPosted: Wed Jun 17, 2015 12:21 am
Thanks for the info. I will let my friend know he needs to go find the right Compressor Bracket for his 1.0L.
Only thing I have extra is for a 1.3L.
Fainya
PostPosted: Wed Jun 17, 2015 2:12 am
No problem.. By the way, if your friend's car is not a MK2/3 and is a MK4/5, the 1.0 and 1.3 engine A/C bracket appear to use the same part, GM PN 91172201
Tom
PostPosted: Wed Jun 17, 2015 6:55 pm
How about the bracket off a late '92 1.0 like this?
PostPosted: Fri Jun 19, 2015 3:10 pm
Yes that is the bracket he needs.
Fainya
