It is currently Wed Feb 21, 2018 11:53 pm
PostPosted: Thu Jul 23, 2015 10:06 pm
I've got a swift with 108k miles on it, runs pretty good, but once I drive it around for about 15 minutes or so, and come to a stop, the engine begins to shake, it starts to idle low, and sometimes it will stall out. Other times I will try to drive and it has very little power and rolls along slowly with a deep low buzz sound coming from the exhaust, when I shut it off it always fires right back up and then runs fine after that for a while. sometimes when I come to a stop and it starts to shake, if I throw it into neutral right away the idle returns to normal and nothing happens, but not always.
So far I have replaced the following: battery, starter, alternator, water pump, harmonic balancer, timing belt, thermostat, spark plugs, radiator/tubes, oil/filter, and coolant.
Any ideas on what it could be??? Ive been told it might be the o2 sensor, a bad or dirty throttle position sensor, or a bad or loose crank gear. Any input would be greatly appreciated.
