It is currently Sun Jan 21, 2018 9:40 pm
PostPosted: Sat Sep 12, 2015 9:11 am
i have bought new headlights, but dont know how to change it .
PostPosted: Sat Sep 12, 2015 11:19 am
You'll probably have more luck asking that on redlinegti if you haven't already. This sites more about the old stuff
___________________
89 Swift gti
PostPosted: Mon Sep 14, 2015 9:12 am
ok thanks a lot !
PostPosted: Wed Sep 16, 2015 8:03 pm
:werd:
We never received the world market Swift here in North America, you won't find much info on here. What I would recommend is look at where the mounting studs are on your new headlight, and figure out where they would be hiding inside the bodywork. Chances are you may have to remove some of the bodywork to get the best access to the fasteners. Unbolt everything that's in the way!
Users browsing this forum: Bing [Bot] and 3 guests
