It is currently Sun Feb 25, 2018 6:18 pm
 Post subject: Turbo Sprint Won't Idle
PostPosted: Sun Sep 27, 2015 7:33 am
All,
Been a while since I posted, but the car's been running well, so lurking is all I really had need for.
Until now.
My 1990 Sprint Turbo has developed a problem in which it refuses to idle. It starts fine, it runs fine if I'm on the gas, but the moment I get off the gas, it's like I switched the car off. It doesn't even attempt to hold idle, the tach just winds down to zero.
Any thoughts?
Joe
PostPosted: Sun Sep 27, 2015 8:03 am
2 things come to mind.
a really dirty air filter or a nearly completely clogged catalytic converter.
PostPosted: Sun Sep 27, 2015 9:26 am
The cat is all but new, but I'll check the air filter and check back -- thanks!
PostPosted: Sun Sep 27, 2015 12:43 pm
Look for a vacuum leak
If the filter is that dirty, it will do the opposite. Idle fine, but not rev up
PostPosted: Sun Sep 27, 2015 12:45 pm
Check for codes.
What was the last thing you did to the car before it started screwing up?
PostPosted: Sun Sep 27, 2015 1:53 pm
SOLVED!
Turns out the rubber hoses on the turbo intake were completely shot and leaking VERY badly. After removing them and "repairing" them (duct tape -- I'll replace that with electrical tape later and start looking for proper, new replacements), the car runs beautifully.
Thanks for pointing me at the airbox, I would not have found the problem otherwise.
Joe
PostPosted: Sun Sep 27, 2015 2:12 pm
Vac leak. Surprise :lol:
The turbo motors are sealed, so if they won't idle, but otherwise run OK, 9 times out of 10 it's a vac leak
PostPosted: Mon Sep 28, 2015 7:01 am
I know, huge surprise, right?
Now, does anyone know where I can buy solid pipes and silicon couplers for the rubber that connects the airbox to the turbo intake on a '90 Sprint?
Joe
PostPosted: Mon Sep 28, 2015 5:10 pm
http://www.frozenboost.com/
