It is currently Sun Feb 25, 2018 9:28 pm
PostPosted: Sun Nov 29, 2015 4:30 pm
Putting a new head gasket on my 90 swift gt engine, what is the best gasket to purchase? Engine is rebuilt and stock.... also do I need new head bolts? Not sure if they are stretch or not...
PostPosted: Sun Nov 29, 2015 4:40 pm
If it's a stock motor a most any gasket should work but I would go with a felpro. They make decent gaskets and will be more than adequate for a stock engine. Also i may be mistaken but think the stock head bolts are torque to yield and will need replaced.
Listen to thine engine and mind thine tach, lest thine whirlybits seek communion with the sun.
1989 Suzuki Swift GTi, A work in progress as always.
PostPosted: Sun Nov 29, 2015 11:03 pm
they are stretch
you can reuse twice if they are no signs of stress
I can't stress enough that all head gasket surfaces be clean and dry so the graffite gasket can heat and seal
and if i could add
run a few heat cycles then revist torq spec 25-35-60lb to finish.!
Start from middle and torq outward....in a circle pattern (refer to factory service manual)
t3 ragtop wrote:
suprf1y wrote:
jrjd wrote:
PostPosted: Mon Nov 30, 2015 1:12 am
they are stretch
and if i could add
run a few heat cycles then revisit torq spec 25-35-60lb to finish.!
JV&S, thank you! :) :)
I wouldn't have thought to do the re-torque. I'll remember it the next time around!
I also suggest you go with Fel-pro because I've found that not all head gaskets are created equal. Some are not properly designed for engine rebuilds where the heads are... "well seasoned":
viewtopic.php?f=5&t=50653
There may be others, but I've found in years past that the FelPro head gasket has all the proper sized holes and met my needs perfectly. A buddy of mine swears by the NAPA brand head gaskets, but I've never seen one to compare to the Fel-pro openings.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
