It is currently Mon Feb 19, 2018 8:38 pm
PostPosted: Mon Jan 04, 2016 4:12 am
hi all newbie here, it started by wanting to stall when stopping and then one day it just stopped on the Hwy. The problem I'm having is I cannot find the igniter! There's nothing at the coil ! This is what I've done so far:
Replaced the pick up coil (that's the only thing in the distributor).
Replaced the coil.
Replaced the ecm with one that was working.
Checked all the fuses.
I'm getting 12volts at the coil.
Before this happened I had replace the brake light fuse, it kept blowing than I disconnected the shifter lock, replaced the fuse and it was fine. The strange thing is when the brake light fuse used to blow it would stop the tranny from shifting automatically but was ok if I shifted manually I.e. From 1,2, than D.
I'm stumped any help would be greatly appreciated!
P.s. Would love to attach pics but pic size is limited and have to figure out how to reduce size!
