It is currently Sat Feb 24, 2018 7:09 pm
PostPosted: Sat Jan 09, 2016 3:43 pm
HELP NEEDED ASAP......Hi all new to this group .been having a problem with my car a 1992 swift gti the car just won't start the fuel pump will not kick in off the ignition but when you wire it direct to a battery I works fine also getting 0 spark the coil is getting power but producing no spark. The car has been to a garage to be looked at for about 2 months but all they could figure out was that there is something causing a diode to blow in the ecu. Checked earths relays fuses all seems fine if any one could shed some light as to what could be causing this problem that would be very very much appriciated as the car has not been running for about 3 months just running out of ideas of what to try next need to get this problem solved. Thanks.
