It is currently Wed Feb 21, 2018 1:16 am
PostPosted: Mon Jan 11, 2016 12:10 pm
I recently bought a 1999 Suzuki Swift 1.3l 4cyl 16v AT(and AC) with high miles.
I bought it in non running condition.
The mechanic diagnosed and fixed a broken flexplate.
The car smokes at first start up and possibly on hard exceleration.(no moisture at the tailpipe.)
The oil is clean as is the antifreeze.
I did the "sizzle" test.Placed oil from the engine on a hot plate and it bubbled and sizzled indicating water in the oil.
I took the car for a drive(approx. 120 miles.) It ran beautifully.It excelerated on steep hills and idled smooth.
Does this sound like a head gasket or bad rings?
Also,there seems to be no supplier of head bolts for this vehicle??
thank you
PostPosted: Mon Jan 11, 2016 1:40 pm
Very common with those motors. Likely valve seals or guides.
If it runs OK, just drive it.
