It is currently Tue Feb 20, 2018 2:21 pm
PostPosted: Fri Jan 29, 2016 6:26 am
I have decided to rebuild my transmission myself, I don't want to do it twice so I want to buy a complete QUALITY rebuild kit. Can someone point me in a direction, and where to get additional transmission parts if any that don't come with a kit are damaged. Are their more than one 5 speed transmissions for a 93 swift with the 1.3 ltr 4cyl?
PostPosted: Sun Jan 31, 2016 4:17 pm
Check with fainya, He rebuilds them for others and he way be willing to steer you in the right direction or tell you what he uses (unless it is a trade secret.) he seems to have found the magic formula. Now if we could only find someone to reb uild those trannys from those pesky sprint turbo's .best wishes, Jonathan
Current stable:
PostPosted: Mon Feb 01, 2016 3:18 am
There's no magic formula and it's not rocket science, most of the kits are pretty similar and fine for road cars, if you're racing you should choose better quality bearings than whats supplied in the kit, the difference is making sure the low speed hub and 1st and 2nd gear syncro teeth are in good condition, people seem to think throwing new syncro rings will solve all the shifting problems :roll:
If you drive your car until it won't shift into 1st or 2nd at all then you'll need to replace the low speed hub and probably 2nd gear and possibly 1st, if you drive your car until you get a slight 'snick' when grabbing 1st or 2nd then swapping out the 1st & 2nd syncros is probably all that is required, it's pretty simple, continue to drive on a worn box and replace lots of parts or fix it early...
Jonathon there's nothing difficult about fixing mk1 boxes, I've fixed dozens of them, it's sourcing parts thats the problem, unlike the mk2/3 which share syncro rings, bearings, seals, 1st,2nd,3rd and 4th gear with brand new suzuki K series transmissions, the mk1 is a 30y/o car that shares no gearbox parts with anything else.
PostPosted: Mon Feb 01, 2016 10:14 am
What symptoms does your transmission have?
I can probably provide hard parts if you need a gear or something like that. I'm fairly confident most al of the kits will contain exactly the same parts even with different brands or suppliers. Any kit you buy will work well for you in my opinion
PostPosted: Wed Feb 03, 2016 10:18 pm
Transmission kits for the mark 1 5 speeds are hard to find in the USA. I here that in Europe you can still find them.
Gocarter has found a place in the USA that makes gears. I just got the information tonight and will be calling them in the morning.
5th gear sets and 1st gear are then parts that are getting hard to find. While I am at it I will get prices on the sliders for 1st to 2nd,
and 3rd to 4th. If his prices are right, this means we can get different gear ratios. More to follow tomorrow.
Fainya
