It is currently Sun Feb 18, 2018 7:13 pm
PostPosted: Sat Feb 20, 2016 3:22 pm
I got a suzuki 1,6 16v 4x4 (g16b spi) and i can get spark or fule. puld the dome fuse and checkt the flach cod firs 12 = god chrank 10sek got cod 42 cam angel sensor in dizzy.. I have a 2 wier vr-sensor in my dizzy and if i ohm it its whith in spec! 140-180 ohm my reds 156 ohm. but when i have the key in ingnition i dont get pover to coil and i dont get pover to my dizzy sensor.. so im thinking that a got a bad ecu??? fast answers please.
PostPosted: Sat Feb 20, 2016 4:27 pm
I chekt the ecu pins thath gos to the dizzy vr-sensor and ecu dosent send any pover to the sensor. and i check the cabels and they ar ok. any ides?? is the ecu broken?
PostPosted: Sat Feb 20, 2016 6:28 pm
the cam angle sensor does not receive any power from the ecu. it is a variable reluctance sensor which generates a small voltage and that small pulse is read by the ecu.
it's a bad idea to connect any meter to the ecu as it typically blows them up.
check the small 15 amp fuse in the relay rack under the hood in front of the left side strut tower.
PostPosted: Sat Feb 20, 2016 6:40 pm
ok the suzuki workshop sad that i wod be 12v to the sensor. all fuses ar god the fule pump runs but i still dont get any fule or spark.. wahts next to check?
PostPosted: Sun Feb 21, 2016 12:32 pm
over 40 views but only one replay :( anyone have any idea what could be wrong ?? because I 've run out of ideas now ..
