It is currently Sun Feb 18, 2018 1:29 am
 Post subject: No turn signals
PostPosted: Tue Feb 23, 2016 2:42 pm
Turn signals stopped working today. The car is a 91 vert with wiring harness from a 91 t3. Hazards work fine, brights turn on and off from the column switch.
What should I replace first?
 Post subject: Re: No turn signals
PostPosted: Tue Feb 23, 2016 3:32 pm
The whole column switch might need to be replaced
___________________
89 Swift gti
PostPosted: Fri Feb 26, 2016 2:09 pm
Plugged in a good working column switch but made no difference
PostPosted: Fri Feb 26, 2016 8:45 pm
i'd start with the more simple and less expensive things like the turn signal flasher relay. :wink:
PostPosted: Sat Feb 27, 2016 1:21 pm
It wasn't exactly an expensive fix as I have 4 sprints ha ha ha.. I didn't completely install the switch, just plugged it into the fuse box. I can't see it ymaking a difference unless is the switch is grounded through the steering column the same way the horn is?
My hazard lights still work fine, do they not run off the same relay as the turn signals? If the relay was no good my hazards would stop working, correct?
PostPosted: Mon Mar 21, 2016 1:56 pm
After replacing the relay and signal switch they still do not work. Hazard lights work fine.
PostPosted: Tue Mar 29, 2016 2:49 pm
I have now replaced the column switch, relay and hazard switch all from a parts car with known working signal lights. Hazard lights still work fine. There is no apparent buzzing when activating the signal light. I could not find any burnt or melted connectors in the wiring harness.
Amy suggestions would be much appreciated
EDIT:
Upon closer inspection I found the fuse to be blown! Next time I will completely remove my fuses to test them rather than leave them in the box and just look.
